12V Electric Blanket
- Has thanked: 298 times
- Been thanked: 151 times
A while back Bugger alerted us to the availability of 12V Electric Traveling Blankets at Midas.
So last week I went in and picked one up... ... quite pricey though at R600 ...
Its a thinnish rectangular fleece of 100 cm by 145 cm and comes folded in a carrybag smaller than Mannys BriefCase.
With this cold spell I tested it using a wanked out battery I keep round the house for powercut lighting, cellphone charging etc
Works quite well and lasted about 4 hrs before the battery faded ... think it draws 5A at max.
It probably needs TLC to last so Ricoffy etc would need avoid over active antics, using it as Judo mat etc etc
- Has thanked: 804 times
- Been thanked: 1347 times
Chas, if R600 is 'pricey' - what would you consider cheap? R8.75?
But it does sound small @ 1000mm x 1450mm
- Flipside
- Has thanked: 16 times
- Been thanked: 48 times
How much space do you want to heat up, you dont have to warm up a villageMad Manny wrote:Chas, if R600 is 'pricey' - what would you consider cheap? R8.75?
Flip
Awesome: Suzuki Jimny;
- Has thanked: 478 times
- Been thanked: 120 times
These blankets are actually seat warmers I suppose.
Bugger bought 2 some time back and he said that is what they were advertised as.
Thus "small" for a bed.
I also have a normal double electric blanket (which I could also carry), and a 1500w inverter and 1 or 2 large batteries, etc. etc.
… and yes that works just fine, but this should be much simpler and easier, smaller, no inverter, quicker set-up etc.
& equiv to about mid-setting on the normal E—Blanket which is about 7-10 the volume to pack…
… yes … would be better forHenriSteyn wrote: ↑Mon Aug 30, 2021 6:38 pmThese blankets are actually seat warmers I suppose.
Kolbe than Etzebeth …
Kurt, chill. Chas bought an electric blanket just in time for summer.
By the time he gets to use it he would have misplaced it...
SNOW-PIERCER
... a few days ago Natal was covered in a vast blanket of snow,
... in a few weeks I’ll be calmly gliding along atop the mighty Drakensberg.
It’ll be serene and peaceful up there ...
Manny will be hundreds of Kilos away and young Kurt will still be thousands more,
lurking aimlessly around in some drab and drizzly N.London car park ...
SNOW-PIERCER
- Wave
- Has thanked: 1 time
- Been thanked: 8 times
adding....
I also only use the electric blanket to pre-heat the bed, so it only needs to run for 15 mins or so while you go have a hot shower... no need to drain you battery in 4 hours or less...
I also have a small cheapie modified sine wave inverter that powers a 220v electric blanket perfectly, worked like a bomb in my RTT
… agree Geoff … it was just an icey morningWave wrote: ↑Tue Aug 31, 2021 7:53 amadding....
and thought appropriate to test the blanket and see if even an old (small 60AH) battery (that can no longer even kick over the platcar engines) would suffice !
- Has thanked: 147 times
- Been thanked: 264 times
I have bought 2 a couple of years ago and price was R200 and can run mine ALL NIGHT LING no problem
Bought another 2 to leave in my Autovilla
Works very well and I enjoy my bed pre warmed
SJ 410 Tiny Tiger
SJ 410 Tiny Tiger
- Flipside
Last time in that mountain in pouring icy rain, I had a great sleep in my sleeping bag. In a dry tent. No crazy running around outside. Just be prepared
Flip
