BF tyre side wall cut - what effect will one tyre change have?
Good evening all you wonderful forum members.
I managed to cut a sidewall it seems, at Sandturion of all places since I was only mall crawling since then... The tire is stuffed, I asked an expert plumber (Manny) this morning and he agrees.
What negative effects can I expect if I only change one tire? For the noobs, the Prado is permanent AWD. The BFs have 10k kms on them.
Renier_c
Been thanked: 11 times
Post by Renier_c »
Is the spare a new tyre?
If so. Buy 1 tyre. Put that and the spare at the front. And make the used one the spare.
Hi Rainier,
Spare is just a Goodyear, the sidewall cut is bad so the tire is a write off, thus I will sit with 3x basically new BFs on the vehicle and one cheapy as a spare
Renier_c
Post by Renier_c »
Im sure with only 10k km on them it shouldnt be a problem to only replace the 1
Mike-PS
Has thanked: 14 times
Been thanked: 18 times
Post by Mike-PS »
What size is it - might have a spare /s
Mike it’s 265/65/17
Leon
Been thanked: 26 times
Post by Leon »
Ja stem kry maar n nuwe tyer kan nie met so tyer ry nie. Ek vra net het jy bande afgeblaas toe jy gaan ry het.
Has thanked: 376 times
Been thanked: 38 times
Leon , klink of hy daai band in die dorp gesny het ?? As ek reg lees .
Mike-PS
Post by Mike-PS »
LesseW wrote:Mike it’s 265/65/17
Ok - so I have a spare 265/70/17 Ko2 -
However I’m thinking of changing my shoes very soon to Grabbers and will have 5 x spare BF’s 30% to 40% tread - something to consider ?
If you want to
Ja Leon ons het afgeblaas, Johannes nee die band het op n 4x4 trail seergekry
If you want to
Thanks Mike but My first choice is to change the one tyre only.
Been thanked: 1313 times
It's spelt Tyre. Not Tire or that word Leon used.
Santurion is a 4x4 Track, Johannes. Sharp rocks (unlike you lot).
Wessel buy two, toss the cut one and the normal spare...
LesseW wrote:
Tue Feb 23, 2021 5:49 pm
Hi Rainier..
*Renier
Mad Manny wrote:It's spelt Tyre. Not Tire or that word Leon used.
Tire. If only pommies could read Afrikaans then it would’ve been a lot easier.
