KRRRRRRRR
Has thanked: 79 times
Been thanked: 217 times
Shane you need to program the injectors to the DCU. Standard procedure with D4D injector swap.
Do not know the ability of your scan tool but you can do it yourself. There is a 30 digit code on each new injector that needs to be entered into the DCU program.
Toyota dealer would definitely be able to sort it out.
And yes don`t believe the crap they talk on Aussie forums
Has thanked: 88 times
Been thanked: 179 times
18 posts of talking kak...
Has thanked: 213 times
Been thanked: 339 times
So educate us o wise and omnipotent seer...
FWM
Has thanked: 32 times
Been thanked: 24 times
Post by FWM »
Just for interest sake. What kind of diesel are you using?
If 10ppm have you tried 50ppm? I have noticed with my NP300 and Landy that they ran smoother with 50ppm.
Has thanked: 602 times
Been thanked: 245 times
FWM wrote:
Tue Aug 30, 2022 7:25 pm
Ek dink Prof het die beste raad hier gegee.
grips wrote:Shane you need to program the injectors to the DCU. Standard procedure with D4D injector swap.
Thanks Grips - did that when I put the new ones in.
FWM wrote:Just for interest sake. What kind of diesel are you using?
50ppm Out here in the Free States 10ppm is not that readily available yet.
Bugger wrote:18 posts of talking kak...
Why would you say that?
Has thanked: 589 times
Been thanked: 1080 times
Shane Google "Playing Chess with a pigeon", then you'll understand what Bugger did on this Thread...
