Mean Mother Manny's Mikem Coil Conundrum
Manny I collected my Vehicle this morning and I am super impressed again. I had the progressive coil/Bilstein on my Prado150Tx and now the same on my 120.
Harder ride but a lot better than the kk Camil suspension I had on, Camil suspension looked impressive but it was junk IMHO.
I also collected my BL this morning and the sag on the Prado now vs with Camil, is like comparing Manny to a good person[emoji16].
See pics of the Prado with the new Mikem setup. i have to say that I almost went with another supplier if Manny did not intervene to get them to start replying to their clients…..
Has thanked: 376 times
Been thanked: 38 times
Looking good Wessel.
After...
Mike-PS
Has thanked: 14 times
Been thanked: 18 times
Post by Mike-PS »
Much better Manny but is the daily ride unladen too hard ?
I can’t talk on Manny’s behalf but my Prado’s new suspension is very stiff but, I’d gladly take it over rear sagging.
Mike-PS wrote:
Thu Apr 14, 2022 5:32 pm
Not at all...
LesseW wrote:
Thu Apr 14, 2022 6:07 pm
Drop your tyre pressures...
Mike-PS
Post by Mike-PS »
There is no friken middle ground here - either to stiff to soft - pity there are no blue pills to sort out our problems
Get a kidney belt, sorted!
Bogaards
Has thanked: 57 times
Been thanked: 88 times
Post by Bogaards »
Maybe I should take my Fortuner to Darrel as well. Rear also sags when loaded and when towing. I have OME Medium duty at the back.
Has thanked: 230 times
Been thanked: 360 times
I've always said:
- if you want comfort or articulation, suspension needs to be soft
- if you want load capability, suspension needs to be hard
No amount of progressively wound coils will give you a perfect solution in all situations. In fact, they can sometimes be worse than standard.
Also, the correct shocks must be used: I would say on a multi-use vehicle with multiple roles and load profiles, compression and rebound adjustment would be mandatory (but who has the bucks for remote reservoir shocks........)
Also, airbags should be used as a last resort, and you better understand the limitations and risks.
Lastly: spec and fit springs and shocks for the 80% of drive conditions that you will experience.
… or get an old Classic Range Rover
sprung as soft as silk
with a self levelling unit contraption
at the back …
… can fill back … and tail gate
w full load bricks …
"with a self levelling unit contraption"
AIR SUSPENSION...............basically air bags. See my comment.
… yes, I Think (?) D1s and D2s had/have same setup.
Thu Oct 06, 2022 1:59 pm
D1. Basically a RRC with a better body.
D2 had ACE which was a lot more complex.
