Give Andy a call 082-870-1181 - he may be able to help, if not maybe he can point you in the right directionErin wrote: ↑Thu May 28, 2020 12:23 pmThank you, I need someone that can come and check / repair a door on a Smeg oven. The oven door doesn't close properly and I'm buggered if I can see how to adjust the hinges, if that's even possible.
If they can talk nicely (without using a big hammer) to the ice maker / dispenser on a Defy fridge that will be a bonus.
For obvious reasons, I need someone that can come to my house in Edenvale, Gauteng (both are damn heavy and I'm not going to take them anywhere).
Looking for a Product or Service
Forum rules
Please note that adverts are automatically deleted after 30 days
- Wave
- Has thanked: 1 time
- Been thanked: 8 times
- Has thanked: 804 times
- Been thanked: 1347 times
I'm looking for a Home A/C Tiffy.
I have an LG Artcool Aircon. Installed in 2006.
If I use it on HEAT Mode it starts & goes to Defrost mode & stays there.
It's either the circuit, or the reverse valve or the sensor or board.
I spoke to the installer, but he just wants to replace the entire unit.
So someone who repairs Split unit Aircons (LG) in the West Rand area.
Thanks...
Thanks...
- Has thanked: 298 times
- Been thanked: 151 times
Have a 1975 Series 3 88” 2.25L petrol ...
... but chassis is not in very good condition and I want to patch/case/repair the main chassis rails between the wheel arches
... so/and to be done without removing the Engine, Bulkhead or Axles ...
... I will remove the cab and flooring and bodywork to expose the main rails ... fuel tank already removed.
... May be awkward but rails will be accessible from above and below ... nearly all welding will be from above .
Can anyone recommend a (preferably coded) welder that would/could do this sort of doctoring work ?
- Paul#25
- Has thanked: 381 times
- Been thanked: 283 times
I have an AEG (Electrolux) deepfreeze that is not operating correctly. Can anyone recommend a good fridge repair guy to contact, preferably based in the East Rand. I can be contacted on zero 8 3 three 7 9 three 4 7 one.
- KurtG
- Has thanked: 11 times
- Been thanked: 13 times
Hi guys, I’m hoping for assistance with my wheelbarrow.
I need the axle repaired, it seems the shaft has rusted through and it may need replacement, and I don’t want to pay more than the cost of a new Lasher from Makro.
Does anyone know a decent wheelbarrow repair centre in or around the northern suburbs of Johannesburg?
- Has thanked: 610 times
- Been thanked: 257 times
Try gentler thrusts and lube next time.KurtG wrote: ↑Wed Jul 15, 2020 6:48 amHi guys, I’m hoping for assistance with my wheelbarrow.
... you could try Sweet Manny MaloneKurtG wrote: ↑Wed Jul 15, 2020 6:48 amHi guys, I’m hoping for assistance with my wheelbarrow.
As he wheels his wheelbarrow
Through streets wide and narrow
Crying " axles and shackles , revived, aligned, oh ... “
- Martin de Jager
- Has thanked: 47 times
- Been thanked: 157 times
Leon Ek het n baie mooi stel bande meer 75% lewe al vier bande sonder enige puncture of sidewall skade, 31x10.5x15 Brutus, r R7200,00 rerig goeie koop.
