4WD Action from Australia, mate!
- Has thanked: 453 times
- Been thanked: 890 times
I've been trying to find out more about Australian 4WD Action.
Seems it started with Graham Cahill, but Shaun Whale was brought in.
Shaun worked at an Aussie 4WD magazine.
Graham himself was actually a bit of am ASPW but covering nature photography.
Graham has his own channel called EcoMuse.
So Graham is actually the guy with the location & historical knowledge.
Shauno has the 4x4 knowledge & media back ground.
There is also a large team behind them, obviously.
There is no Wiki entry - but it seems this all started emerging in 2010...
- Paul#25
- Has thanked: 238 times
- Been thanked: 206 times
There were interview segments posted on the YouTube channel a while ago that touched on each of their history. Graham also did a good interview with the guy from the Fork to Fire chanel. Some nice background there too.
I notice that Graham Cahill often discusses pressures.
He says on those trails his general driving pressure is 25PSi.
That's just under 1,8 Bar.
Quiet hard...
Obviously he deflates further if required - but they never deflate like we do...
Probably explains why they use the winches so often?r
Quiet hard...
- Paul#25
Looks good as well. Thanks for the heads up.KurtG wrote: ↑Sun Aug 18, 2019 5:58 pmA new series I stumbled upon... not too bad.
https://youtu.be/UI96DSBN7UU
- KurtG
- Has thanked: 11 times
- Been thanked: 13 times
I like the design of these drawers and the table solution is brilliant. No steel runners saves a ton of weight and less maintenance I would assume.
https://youtu.be/mVewdSFwbcg
