FJ cruiser starter issues after mud pit
Last weekend I took my FJ through a mud pit, it was fun and all was well until Monday.....
I assume my starter took a hammering with the mud since it does not want to turn every so often. Battery is full and working.
The FJ’s starter sits in an awkward place, has anyone removed one before? Else, any Cruiser mechanics that you can suggest?
Regards
Has thanked: 453 times
Been thanked: 890 times
Avoid mud... and water.
Have you cleaned all the mud off properly?
What does it do when 'It refuses to turn'..?
Just click, click, krrrrr.. ?
Or is it dead. Like there's no battery...?
henris
Post by henris »
Probably got some mud inside. Best is to service that thing. Else the dried dirt will consume that starter.
Has thanked: 39 times
Been thanked: 134 times
First check connections. Could be a connection that got corroded by water. I will start investigating the connections on the starter first. Bad solenoid connection have the symptoms you describe. If not mud or water in the starter
Has thanked: 71 times
Been thanked: 145 times
Agree with Grips
Always first check all connections
And make sure battery terminals are clean
Other wise mud in starter but starters are generally fairly good insulated from the elements
Has thanked: 242 times
Check heavy +ve feed (red cable) to starter
& solenoid wires not dragged loose or out
by mud and stuff ...
Mannys not far out asking if theres
nothing ... solenoid cluck ... or/& starter turn ?
Alles loop reg, altyd reg..... TOYOTAAAAAAAA
50% of the time the starter works, 25% of the time not even a click and the other 25% the solenoid clicks but no start.
I pressure washed the engine, from the top and bottom. Getting to the starter is difficult but i got my pressure washer in there.
KurtG wrote:Alles loop reg, altyd reg..... TOYOTAAAAAAAA
Jip, i mean the mud pit was not so deep after all
Has thanked: 238 times
Been thanked: 206 times
Did you walk the obstacle before driving into it?
My opinion, no one should drive through something like that with a vehicle that the are not prepared to destroy completely. To drive into something like that with a normal vehicle is crazy.
Has thanked: 94 times
Been thanked: 155 times
If you play you will pay. The rest of the damage will appear over time!
Note to self: “don’t buy an FJ Cruiser from Wessel”
AndreasR wrote:If you play you will pay. The rest of the damage will appear over time!
Wise words.
Manny always k@k on me for going too slow. I have paid the price. Thirty six years of serious 4x4. I have the trophies to show. Stripped diff's, gearboxes, transfer cases and too that add a good lot of side shafts.
Pitty fun comes with a price
Wessel double check that you have cleaned out all mud from the radiators. They tend to clogg up and bite you sometime later
Paul#25 wrote:Did you walk the obstacle before driving into it?
Could not walk it as my pt shorts would get wet..... i had to do it on instinct
