Brad Harrison: Not White, is he Coloured?
Brad Harrison Plugs...
Most are Grey.
But you get other colours.
Which colour gets used where?
Then there are two sizes
Does it matter?
Should we be unified & consistent?
My understanding is the following, but I’m keen for expert opinions:
Red = supply (as in charging from car)
Grey = usage (as in lights etc.)
Blue = Solar
Green = plug into a vegan’s anus with high voltage
Yellow = plug into the sun for quick charging
[emoji2371]
__________________
Oh and the sizes take into account the amperage. The normal smaller size that we are all used to is limited to 50A, the larger ones take much higher current in stages up to 300A etc.
__________________
I personally use Red for supply - so the Brad Harrison sticking out the back of Fearless is Red.
Remember you cannot plug one colour into another - so Red goes to Red, Grey plugs into Grey etc...
The problem is, if I hypothetically break down (Hypothetically, because Fearless is a Toyota) & I ask someone to tow my trailer there could be problem if the person has a Grey & mine is Red.
Besides, I have a short Red to Grey 'converter' to get round this - my Compressor also has a Red Brad Harrison - so if a mate wants to use it I can plug the converted - I also have a Red to Battery Clamp converter & a Red to Hella converter....
Obviously standardizing on Grey is more practical.
But we use colours to identify. For example, if all mine were Grey (as they were) & someone plugs my solar into the wrong plug, then it could be a problem.
But usually, like most campers, I plug in my stuff to my stuff.
So, do we need different colour Brad Harrisons & if so, what do the colors mean?
Solar should be Green - as Greta would say...
There are about 3 makes knocking around ... look identical , but don't mate (i.e. interconnect Manny ...)
The lugs for the heavy amp ones have thick walls ... hard to crimp, but you probably don't need them.
I have the ones from ODW, the ones from 4x4Direct & the Bushpower ones - they do interconnect - but the same ones slide in easier...
Has thanked: 377 times
Been thanked: 275 times
Sat Jan 25, 2020 4:11 pm
From my research, on both the Internet and discussing this with people in the industry, Blue is the one that they are trying to get standardised for solar inputs.
What is a "Greta" by the way?
Has thanked: 466 times
Been thanked: 116 times
I use grey for 12v and red for solar.
However I have chosen to use a 220v 3 pin industrial plug on the caravan simply because it is has a spring loaded cap that seals well and simply looks much better than a BH.
Alternate plug to BH is Anderson.
Paul#25 wrote:
Sat Jan 25, 2020 6:42 pm
That young lady who craps all over us for polluting.
I wonder how she got to Davos. Hopefully by bicycle.
Shivers down my spine should she have used an aeroplane to get there.
From what I can gather, Anderson makes Brad Harrison.
In some countries they call the Brad Harrison an Anderson Plug...
Anthony Forgey
Has thanked: 70 times
Been thanked: 65 times
Post by Anthony Forgey »
What Kurt said:
Grey - Power from auxiliary battery to fridge etc
Red - Power from Alternator
Blue - Solar
The colors of Anderson plugs indicate Voltage. It prevent for example plugging 12V into a 24v system or any other voltage.
It is however convenient to use different collars for battery input, solar and outputs. I have rigged my systems like that.
12V = Yellow
18V = Orange
24V = Red
36V = Grey
48V= Blue
72V= Green
80V = Black
96V = Brown
120V = Purple
144V = White
Grips, stop ruining our 12V only discussion with all your fancy colours for all the voltages you like to play with [emoji1787]
__________________
Colors keep us Sparkies alive [emoji12]
