I recently bought a 2012 FJ Cruiser with 90k km on the Clock, on Thursday I put 4x Pirelli AT+ tires on to improve it's 4x4 capabilities even more. I had a FJ before and it was very capable without any mods, with my previous Prado I put a Mikem/Billstein suspension on which gave me 40mm lift but a stiff suspension.
The big question, would I waste my money on a Mikem/Billstein suspension on the FJ and is the FJ's standard suspension good enough? I am not intending to climb "At se Gat" or "Briekmerk" however I would like to do i.e. most obstacles on a 4x4 route.
To upgrade FJ suspension or not?
- Has thanked: 787 times
- Been thanked: 1321 times
I'll ask around - but Mike Nel would know...
- Has thanked: 43 times
- Been thanked: 81 times
Upgrade your suspension
Every person here would tell you different in what suspension you should get. But the choice is still yours. I had and still have Tough Dog adjustable suspension on all my vehicles and I am extremely happy with them
- Has thanked: 295 times
- Been thanked: 150 times
“I am not intending to climb "At se Gat" or "Briekmerk" however, I would like to do most obstacles on a 4x4 route.“
I’m reluctant to dampen your ambitions ...
- LesseW
- Has thanked: 53 times
- Been thanked: 58 times
Chas, thanks for your valuable input, I can always count on you...BushWacker wrote:“I am not intending to climb "At se Gat" or "Briekmerk" however, I would like to do most obstacles on a 4x4 route.“
- GarrethG
Most lift kits the average guy can afford will give you a harder or stiffer ride. I’ve had a few suspension setups in my Fortuner which has almost the same suspension as your FJ. If the bilstein suspension was not to your liking then I would not lift it. I would fit a set of Monroe gas magnums shocks or try get a set of Rancho RS9000xl, these are also imported by Monroe and they are 9 way adjustable. Your local Midas can help they just need to look in the Monroe parts book.
My fortuner runs a full FJ suspension funny enough. Apart from my rear coils I got all the part numbers from a FJ. Of the 4 or 5 setups this has been the best so far. Running the Bilstein B8 5100 shocks and OME heavy duty coils.
