Healthy Sleep
10ppm v 50ppm v 500ppm
Manny, Those price differences are crazy, it really helps to keep an eye out for well priced diesel, then try fill up there, but it has to be convenient or semi-convenient
Michael
Post by Michael »
The lower the sulphur the better!
Sulphur pollutes the oil, so if you're running 500ppm you should definitely change oil every 5000kms.
10ppm is cheapest in my area, so I definitely use it. I personally also find I get better fuel consumption than when running BP 50ppm.
NEW
Been thanked: 2 times
Post by NEW »
All the edenvale guys seem to have a good local station. I paid over R16 per litre at a Sasol in tjoeras. The lowest close to where I can utilize it is a Vooma garage in Horizon who seems to be around R 15.30 for 10ppm....
If its 10PPM then is Sasol fuel ;)
Seems you have found your cheapest station...
NEW
Post by NEW »
Mon Nov 04, 2019 4:09 pm
N
10ppm at a Sasol in Northwold is around R15:30.
Thank you for that one Manny. Think I will start using that garage. They just 2km off the N1 which I commute every day so actually the most convenient by the looks of it...
Has thanked: 453 times
Been thanked: 890 times
NEW - you live in Centurion you Chop!!!
Mad Manny wrote:NEW - you live in Centurion you Chop!!!
Must I explain the meaning of the word “commute” to you?
Well... assuming he works somewhere up Malibongwe - but surely he'd use the N14 then???
NEW
Post by NEW »
I work just off 14th avenue on Ontdekkers....
N14/Hendrik potgieter is 16km further daily and no time saving due to Hendrik potgieter being equally congested...
Assumptions.... the mother of all.... :lol:
Has thanked: 238 times
Been thanked: 206 times
[quote=NEW post_id=19099 time=1573194696 user_id=18
Assumptions.... the mother of all.... MANNY's
[/quote]
There I fixed it for you........
NEW
Post by NEW »
Scratch that.... The Vooma garage on Ontdekkers has 10ppm at R15.15!
Has thanked: 601 times
Been thanked: 244 times
Nee o bliksem kerels, diesel is diesel.
NEW
Post by NEW »
Mon Nov 11, 2019 3:23 pm
Nee man! Daar 'n groot verskil tussen die 10ppm wat ek laas week by Sasol ingegooi het en die 10ppm wat ek gister ingegooi het by Vooma! 'n Hele R 1.12 'n lieter verskil! :mrgreen:
Panda
Has thanked: 2 times
Been thanked: 4 times
Post by Panda »
i use Shell 50ppm tried Sasol 10ppm twice and on both occasions i get worse fuel consumption. almost 1km per Liter.
Has thanked: 39 times
Been thanked: 134 times
Michael wrote:
Tue Nov 05, 2019 8:15 am
The only times I go past 8km/l on the 76 v8 is when using 50ppm.
