more Torque, Power and Force
Another handy spread sheet for those who seem to struggle with the concepts.
Max Torque and Max Power are RARELY made at the same rpm - the Max Torque a motor makes at a certain rpm does not influence the max power at a different rpm!
You also don't need to worry about how much torque or power a motor makes to perform a task, you need to worry about force on the wheels after going through a set of reductions (gear ratios)
This doesn't take into account power train losses etc.
Obviously (I hope) put values in the yellow boxes to get the results out...
PowerTorqueForce.xlsx
(6.93 KiB) Downloaded 210 times
here is a completed example using my JK Rubicon with 35s - obviously, you only change the yellow areas to get the results out...
also bear in mind that an Auto has a torque convertor which is effectively another multiplier until it locks up .
and for comparison, this is an FJ Cruiser sitting on 33s from what I can tell in terms of ratios etc:
Thanks Alex.
Here are the calculations for THOR - first with stock 30.6 inch tyres and then with 33s
