Best Awning to use on a FrontRunner rack
GarrethG
Post by GarrethG »
Hi guys
I installed a FrontRunner slim line 2 to the Fortuner this week.
Now my next step would be to get an awning. Something affordable but easy to open. If I can add sides panels later on to it that would be awesome as well. FrontRunner has a nice awning and you can add panels aswell.
What would you guys suggest?
I’m also not sure on size, the rack is just under 2 meters. So would a 2.5 meter awing be okay ?
Yes a 2.5m awning will be fine. If I were you I would stick with Frontrunner, it just makes sense.
Think very carefully before attaching an awning to your car permanently. Personally I don't think that the number of times that it is used warrants permanent installation which has an effect o n fuel consumption and adds to your vehicle being top heavy. Frontrunner have a very nice one about 3,5m x 2,5m that takes up very little packing space and is very easy to erect with one side temporarily attached to you roof rack.
Nico-MAD
Post by Nico-MAD »
I would stick with Front Runner, They have nice products & good quality
I bought a 2nd hand Eezi Awn 2000, it's 2m long, super quick to set up and is stored in an aluminium case so won't get damaged by trees and thorns. I don't know about side walls though, maybe it's an option, but I did see Bugger was getting some made up for Baboons Pass next weekend.
As Andreas says, it's not something you use often, so choose carefully.
The best awning is the Headout. It’s a sturdy designed thing & you only need one leg, but even that isn’t really necessary. 270 degs
But do you Highveld guys even need something that works in wind? If not then I suppose the regular stuff is fine. How much is the Frontrunner?
https://www.headout.co.za/Headout%20adv ... 0gear.html
Very happy with my Alucab Awning. It comes with one leg (if you want to use it)
They do come at a hefty price though
My setup
Why is that Head-out any sturdier,
or more approproiate to stand up to wind, than other makes ?
... what is the real world unpack and pack away time.
BushWacker wrote:Why is that Head-out any sturdier,
than other makes ?
... what is (real) unpack and pack away time etc
Because Bruce made it. Have you met him? Sturdy & stubborn bugger
rudi.hinze
Post by rudi.hinze »
Mike Nel wrote:Very happy with my Alucab Awning. It comes with one leg (if you want to use it)
Yep, Alu-Cab's 270 is a class leader, in terms of function, construction, weight and price.
For sheer low price yet good quality, aside from Front Runner's pull-out, Easy Awn's featherlite offers a lot for a low price.
Rudi, are you sure the Featherlite is by Eezi Awn?
The Eezi-Awn Range includes the Bat270, Caravan, Lite, Manta, Series 1000, Series 2000, Spoyla and Swift.
rudi.hinze
Mad Manny wrote:Rudi, are you sure the Featherlite is by Eezi Awn?
Sorry, the lite is Eezy-Awn, featherlite is Front Runner. So to correct my earlier post, no complaints about the Eezy-Awn lite from my clients who have bought these from us.
GarrethG
Post by GarrethG »
Thanks guys, I went with the front runner one. The 270 awning is nice but it’s super heavy and the rear Fortuner door requires the awning to be mounted higher.
I went with Front Runners newer range of awnings. It’s a 2.5 meter and I did a 1700 km trip this week and seen no fuel increase. This was also my first long trip with my new exhaust so they may have canceled each other out.
So how about some pictures? Closed and open?
