High cycle 12v acid battery vs Gel battery
Has thanked: 462 times
Been thanked: 115 times
Re: High cycle 12v acid battery vs Gel battery
Quick answer.
Gel battery can take more discharges and deeper rate of discharge.
Has thanked: 751 times
Been thanked: 1282 times
You will ALWAYS opt for the Lead Acid Battery Craig...
Because....
PRICE!
Has thanked: 292 times
Been thanked: 148 times
... why not get AGM ?
Has thanked: 371 times
Been thanked: 273 times
Hunter4x2 wrote:
Mon Jul 08, 2019 10:06 am
I get an energizer gel battery for R750 but no warrenty.
Where are they stolen from Craig?
For that price they are either second hand having been removed from some powerbank at half-life or they fell off the back of a truck. Normal price should be about R1900.00
After a quick Google search here is some good info on these batteries..........
The Energizer (105AH – 12V) Maintenance Free Batteries.
These batteries are designed for backup/marine use only - not for daily SOLAR OFF-GRID charging/discarging
Deltec batteries never need water. Antimony-free plates cut electrolyte loss from gassing. Special liquid-gas separator keeps electrolyte inside.
No filler caps - so no electrolyte contamination, overwatering or damage in use.
Unique wrought lead-calcium grid design means less internal corrosion and efficient current conductivity for more power and longer life. It also cuts gassing, resists overcharge, heat and thermal runaway.
Generous electrolyte reserve, factory checked for purity and specific gravity, is sealed in to last the service life of the battery.
https://www.geewiz.co.za/batteries/5329 ... -volt.html
Paul is correct. Way too cheap to be new. Unless you have special contacts. Who stole them.
Paul.
Are you saying the Engergizer is a Deltec in sheeps clothing?
Cheers
If you give Omar a call from EPS Solar you can get Deltec lead acid high cycle batteries for R1300ea (IIRC)
Brand new, with warranty.
What AH rating is that Wave?
102ah
Very good price. Where are they based?
They are in Crosby, JHB.
HenriSteyn wrote:
Mon Jul 08, 2019 11:24 am
Paul.
Cheers
That is a copy and paste from the website Henri.
Thanks Geoff
Prof
Has thanked: 15 times
Been thanked: 19 times
Post by Prof »
I get an energizer gel battery for R750 but no warrenty. High cycle
Sent from my SNE-LX1 using Tapatalk
That is not a high cycle gel battery...
Prof
Post by Prof »
HenriSteyn wrote:
Mon Jul 08, 2019 11:22 am
There is a back story to this.....wrong battery for the application, changing out for gel batteries
