Does it make sense to buy the Ranger Raptor?
Yes and No
Yes:
-The price is out and at R786K, it's more affordable than a Merc X Class and a VW Amarok V6.
-It comes standard with 33"Rubber and a FOX Suspension. The first thing bakkie owners do when they drive off the showroom floor, is to spend R50K on tires and suspension, so there is already a R50K "saving"
-It comes standard as a Raptor. No need to spend another R10K-R20K on plastic shit to make your Ranger look like a Raptor
No:
-The 2 Liter engine. No thanks. Not for me
-2,5 Ton Towing capability.
- It'll be a beast on gravel and in the dunes. I think it will struggle on technical 4x4 routes
- I don't think it will fit into my garage
https://www.carmag.co.za/news/new-model ... announced/
No
- it’s a Ford
Yes. It’s a clever package & I can’t see why it wouldn’t do well on a trail. It’ll be class leading.
Neil
It's big. I 4x4'd with a Ranger and it was hard work. Tight corners would be a problem
All bakkies are kak off-road owing to them being nothing more than adapted delivery vehicles. The wheelbases are too long & rear departure angles are silly. Then their front & rear suspension configurations are the worst possible option.
So the Ranger Raptor is no worse than any other bakkie. But, the standard mods will set it apart & make it better. Especially the rear coil set up.
One thing not mentioned in any of the advertising is the fact that the addition of 33’s tyres will likely be accompanied by correct gear ratios, which is something that bakkie buyers never do when modifying their bakkies with bigger rubber. Especially Saffers.
So in the real world that 500Nm will be felt, unlike your regular run of the mill Hilux with bigger tyres accompanied by the resultant reduction in power.
Correct ratios is a very underrated modification & it’s mainly the Jeep guys that bother fixing their ratios.
The best example I experience was when I tested a few TJ’s before & after a ratio correction. It was chalk & cheese. The improvement in traction is massive.
So there’s no reason why the Ranger won’t out perform any other bakkie.
Good observations there Neil
Yes - just because it's sh!t hot!
But I wouldn't expect it to perform well off road, looks very wide. Maybe a collectors item in a few years?
If you are going to spend northwards of R700k on a Pick Up, the Ranger Raptor is the best choice.
It has 280mm Ground Clearance, rear Disc & Coil.
I wouldn't buy a twin turbo 2.0 from Ford though.
The 2.3 Ecoburst Petrol motor, as fitted in the US, would be a far better option, in my view....
Maybe FoMoCo SA will look at introducing it here, but I doubt it...
The 2.0 motor is an absolute mystery .
What the actual fornicate*** are they thinking?
Other than that , it’s probably the best bet for a leisure twincab on the market. It will certainly come in less than anything else with the additional gear added as aftermarket goodies.
But if it looks like that it needs some guts .
***Manny says I can’t use the word Fork on the forum
Buy it, use for warrantee period and sell it.
I want one
Apocalypse wrote:
Wed May 15, 2019 2:17 pm
Do you think the 2lt is a kak motor or is it inadequate for a Raptor?
I think the 132kw version D/C is quite good value for money.
Fri May 17, 2019 7:10 am
I think 2.0 is too small for a diesel - especially in a big vehicle. Diesel is great for stonking great big trucks and trains and ships and so on. but as a puny 2.0l they come up short in my opinion.
something like a Raptor needs a bit of urge behind it to really make it fun. loads of on demand torque.
Raptor needed a big friggen motor
Oppies3800 wrote:Raptor needed a big friggen motor
Die post is verander...
