RELAY Connector Problem
Ive had a relay problem on my
defender and various aspects discussed
on our whatsapp group are included here :
First shots shows main feed wire from
battery and a connector plate that has
been hot / corroded ... also blown fuse
https://ibb.co/SKFdCsv
https://ibb.co/jDHLgtr
A temporary solution adapted an exotic
fuse to fit the fuse box to get home ...
https://ibb.co/dtC0nN6
Here is the male relay type in question
https://ibb.co/zQDvkYM
... and the female base that seems to
refect the problem ...
https://ibb.co/wgKkH8f
https://ibb.co/jh3QS7g
A local sparky supplied me with some
suitable female connector spades and
matching insulation sleeves which I will use
... pending acquiring the correct
5-pin female-base...
https://ibb.co/xzvG7CN
https://ibb.co/wM2MSDW
... and here the relevant manual page
indicating affected parts are
Fuse FL1 and Relay 1 ...
https://ibb.co/m9VP4Np
tgwinduna RIP
Post by tgwinduna RIP »
Bushwacker
Hi has the problem been resolved and all sorted
Land Rover Discovery 5
Afrispoor Cheetah OFC
No ... I cant say problem is solved...
... seems the rearmost relay, R1 , is being overworked ... though I have put in a new one, it will, I think, overheat and blow main
fuse F1 again - unless I find the root cause.
Suspects :
possible glowplug/s shorting
possible bad earthing
fuel pump on/off
some other intermittant shorting
... will be checking through these etc. over the weekend...
