12v dc Led work lights working on 24v DC
Re: 12v dc Led work lights working on 24v DC
If the input voltage spec says 0-30V then you should be fine. Wattage (P) is calculated as P=V2/R. R (resistance) should be fairly constant for the light, thus the higher the voltage the higher the Wattage. Wattage=brightness
Anthony Forgey
Has thanked: 86 times
Been thanked: 70 times
Post by Anthony Forgey »
The lights should be fine. They will be brighter.
