and, unlike some others, I am sure you know why you don't need to add 2SO to diesel if you are running a 2 stroke diesel!grips wrote: ↑Sat Apr 07, 2018 6:03 amI had the privileged to work on a real 2 stroke diesel.
Detroit v16 that powered the old Wabco haul trucks.
https://auto.howstuffworks.com/diesel-two-stroke1.htm
Two Stroke Oil (2SO or T2) Discussion Thread
- Apocalypse
- dawidloubser
- Been thanked: 2 times
Oh geez... not on this forum too!!
1984 Unimog 416.163 Doka
- Paul#25
- Has thanked: 238 times
- Been thanked: 206 times
Spent some time in ICU years ago but it wasn't the bike that I was ridings fault. Even at just over a walking pace the car that hits you always wins. I'm now the proud owner of a high milage body.
- Has thanked: 242 times
- Been thanked: 84 times
I have an old RR Classic and the steel feed pipe
portion from the filler cap rusts on the inside
... so I now add a little of the golden nectar
as a protecter (but is also an octane
increasing fuel itself?) and also a little meths
to reduce the water in the fuels sold to us ...
- Has thanked: 454 times
- Been thanked: 890 times
Chas, you are adding 2SO to Petrol.BushWacker wrote: ↑Sun Apr 08, 2018 1:57 pmI have an old RR Classic and the steel feed pipe
But rather add diesel if you want to achieve what you are attempting to achieve...
- Has thanked: 601 times
- Been thanked: 244 times
There is some hidden wisdom in 2SO discussions:
Or rather peculiar similarities.
99% of the time, a guy that uses 2SO in a modern diesel engine also tosses while taking a bath.
- ThysleRoux
[Asem]
FLEX is UNDERRATED
FLEX is UNDERRATED
I have just read a thread on another forum where a wet tosser (see reference above) claims 2so reduced carbon build-up on his exhaust manifold.
Then, when other knowledgeable members take him to town on this brave stupidity, foul play is called.
How else does one reply to a muppet other than to buy him another ice cream and take a video?
The part that concerns me, is the amount of evedentuary weight placed on his "facts". From a scientific point of view, hell from a professional point of view, one can only come to one conclusion: He uses statistics as a drunk uses a lamp post - for support rather than illumination.
- Has thanked: 43 times
- Been thanked: 81 times
I would love to buy you a drink of your choice for the above comment about the wet tosserRicoffy wrote: ↑Fri Apr 13, 2018 7:39 amI have just read a thread on another forum where a wet tosser (see reference above) claims 2so reduced carbon build-up on his exhaust manifold.
Not needed, but thank you anyways.Mike Nel wrote: ↑Fri Apr 13, 2018 8:20 amI would love to buy you a drink of your choice for the above comment about the wet tosserRicoffy wrote: ↑Fri Apr 13, 2018 7:39 amI have just read a thread on another forum where a wet tosser (see reference above) claims 2so reduced carbon build-up on his exhaust manifold.
Well said
I was merely stating the obvious.
We all thought it anyways.
- Jeanvn
Excellent best description I have seen on the 2SO user mentality yet.
It also describes the pissyness they show when called out on their nonsense postings, aka wankers.
Well done sir!
105 Land Cruiser
Amabroekies v6
Amabroekies v6
- ThysleRoux
I grin every time one of the 4's name drops the Chief Spietkop........................
which is every time they get backed into a corner..................................
which happens very often.............................
FLEX is UNDERRATED
FLEX is UNDERRATED
- Jeanvn
Which is one of the biggest problems on a certain unrelated forum, pissyness is taking over.ThysleRoux wrote: ↑Fri Apr 13, 2018 8:49 amI grin every time one of the 4's name drops the Chief Spietkop........................
Really a pity
105 Land Cruiser
Amabroekies v6
Amabroekies v6
- Wave
- Has thanked: 1 time
- Been thanked: 8 times
I thought 2SO was for Two Shots Olmeca?
I have been getting my D4-D drunk for no reason whatsoever...
- Rabbiddog RIP 7/6/21
Nice engine that.grips wrote: ↑Sat Apr 07, 2018 6:03 amI had the privileged to work on a real 2 stroke diesel.
If you want to see the difference in lubricant properties between 2 strike oil and something like chain saw lube, put the 2 stroke in the chain saw lube tank.
Use the chain saw, and then go buy a new chain and blade , I have actually seen this.
And no it was not me
