Two Stroke Oil (2SO or T2) Discussion Thread
Two Stroke oil is an oil called two stroke because it get's mixed with petrol for two stroke motors.
In lawn mowers & Edge trimmers you mix it by hand (add it to the petrol manually) but two stroke motorbikes have a separate tank called an Autolube where you add it & it mixes in with the petrol automatically.
You do get two stroke diesel engines, but they are rare so don't worry about them.
There are people who claim there are advantages to adding 2SO to diesel in your (4 stroke) diesel 4x4. However this is unfounded nonsense.
If you would like to discuss the advantages of adding 2SO to diesel, please reply here to get banned.... :lol:
The advantage of using 2SO in a Touareg 2.5 diesel is that it causes engine failure for a 4e. That’s a great thing 👍🏻
Has thanked: 376 times
Been thanked: 38 times
I only buy Stihl 2stroke. Bloody expensive stuff !!! R122 per liter !
Wow :o :o
Fri Apr 06, 2018 6:31 pm
Wow :o :o
Yes , its bad ! But my brush cutter is now 14 years old !! Very good stuff !! Must say , only i use it !! Motor/engine still as i bought it ! Never been opened !!
Johannes,
I have a 6 year old Ryobi & I use whatever 2SO & it's still working.
It only cost me R1400 & I can buy another one soon with the money I saved not buying Stihl oil!it
:D
I always thought it was called 2SO because it meant “to snake oil” your engine.... I’ve learned a lot
Prof
Has thanked: 15 times
Been thanked: 19 times
Post by Prof »
I have my father's old two stroke brushcutter.
Started it's life on Castrol SAE30 mixed 1:25 with petrol.
I have now inherited it, 35yrs old!
As Castrol SAE30 no longer available, moved to Stihl two stroke oil. Changed mixture to 1:37.
Original engine....and I am sure less carbon build-up as ePikaninni 's Touareg inlet manifolds :lol:
Quack
Post by Quack »
What about Yamalube? Any good?
What a life?!?😜
I just buy WM Penn (Fuchs) from my motor spares spot. lasts about 6 months...
seemingly, for many people, 2 strokes are all it takes.
Has thanked: 377 times
Been thanked: 275 times
Always used Castrol R with the pre-mix motors in the 80's but moved to Motul 2 stroke with the RD350, RD350 and RZ500. Never tried it in a 4 stroke motor as I don't listen to Witch doctor's.
Paul#25 wrote:
Fri Apr 06, 2018 7:44 pm
You owned those bikes & survived? :D
I had the privileged to work on a real 2 stroke diesel. :D
Detroit v16 that powered the old Wabco haul trucks.
https://auto.howstuffworks.com/diesel-two-stroke1.htm
Sat Apr 07, 2018 6:03 am
and, unlike some others, I am sure you know why you don't need to add 2SO to diesel if you are running a 2 stroke diesel!
