Unusual Spanners
Unusual Spanners
Thought I would show you
the wheel-spanner
that came with my 1975 Series 3 88”
Each of 4 legs is 40cm long ...
but I think its an exotic ...
doesnt have that Land Rover look ...
... could prove useful in road-rage encounter ...
[https://ibb.co/chBGk0/img]
That’s one big spanner
I would prefer using one of those with good leverage. The saving space crap you get today is useless
I'm using an imperial size socket on the Disco's wheel nuts. It is a much better fit than the closest metric stuff.
That’s a bit unusual Paul. I thought it wouldn’t have been an option.
When you say LandRover look, do you mean not leaking oil?
Rabbiddog RIP 7/6/21
I think at least 50% of LR spanners are not normal.
Front diff on the D3 is uses an Allen key to check the level, all the allen keys I have are either too short or too long. Had to modify one to work :roll: :roll:
Wed Oct 31, 2018 8:03 pm
Here is a photo of the 1-1/16" socket that I use. Perfect fit on the wheel nuts.
I have made an identical tool as in the pic`s to insert spiral clips in pistons.
0605phr_08_spirolocs_z (1).jpg (6.74 KiB) Viewed 2687 times
Also made this little thing to accurately measure top dead center on an engine with the aid of a dial gauge.
Collected the spanners for the Land Rover Td5 motor I had lazer cut. The 2 smaller one's are for the 2 different types of oil filters and the bigger 2 are for removing the viscous fan. Cost just R690.00 instead of importing from overseas.
