Hand cranking a vehicle
Re: Hand cracking a vehicle
push start for the win....
It is the major issue with autos though. jumper cables are a must in an auto!
Has thanked: 370 times
Been thanked: 273 times
In my experience modern vehicles with electronic ignition systems are quite hard to get going with a totally flat battery. It seems that the ignition system needs a good bit of power to trigger. When trying to push start the car you can land up pushing the car around for a bit without getting it going. In this type of situation a crank handle isn't going to help much.
Has thanked: 109 times
Been thanked: 239 times
If not an Auto and you cannot push start like in thick sand. Jack one rear wheel in the air select 4th gear wound a recovery strap round the wheel and let rip with the ignition switched on.
Fri Oct 12, 2018 12:04 pm
ensure the diff lock is disengaged!
and centre lock
Rabbiddog RIP 7/6/21
Modern engines have too much compression to use a crank handle, so its push start, or as Grips stated, use a rear wheel.
For automatics, either jump start or use a POD or similar.
