EGT?
EGT?
I'm pondering installing an EGT kit on my Tuna, mainly for towing.
Any kits to recommend?
What can I expect to pay?
Where do you install the temp probe? Before or after the turbo?
I’ve only ever heard of Madman units. Anthony Forgey will be able to give you better advice than me.
Has thanked: 787 times
Been thanked: 1321 times
EGT is neccessary when you make an old inferior motor work harder than it was designed to do.
But a modern well-made Toyota motor running well within it's abilities doesn't need that...
Well, it has made it this far...
Mon Oct 01, 2018 2:12 pm
A bit of an anomaly there, MalMan ............................... let's see who picks it up first :twisted:
Flipside
Has thanked: 16 times
Been thanked: 46 times
Post by Flipside »
He is referring to two identical motors [emoji23][emoji23]
Flip
Flipside wrote:
Mon Oct 01, 2018 4:40 pm
^5 !!!! :lol: :lol:
Anthony Forgey
Has thanked: 70 times
Been thanked: 67 times
Post by Anthony Forgey »
there are a few options available:
Madman has an EGT kit which consists of:
1. the gauge
http://madman.co.za/index.php/where-to- ... pathway-26
2. the Probe
http://madman.co.za/index.php/where-to- ... thway-1078
depending on where you mount it you may need a pod or not
Add 1250 for labour
other options are available:
TAS Automotive have a Murphy Kit and a VDO kit
Autostyle have an autogauge kit for 1500 https://www.autostyle.co.za/autogauge-e ... -52mm.html
As far as positioning of the probe....
the ideal position is pre-turbo at the point where the manifold collects just before the turbo.
However, on some vehicles it's just not practical. Some Land rovers for example have a plate at the one end of the manifold which you either drill and tap or you replace with a pre drilled and tapped plate.
Others just have no access to the ideal location (without removing half the fuel system or the EGR system).
In such cases it's perfectly fine to fit the probe in the downpipe as close to the turbo as possible. If this method is used, be aware that there is a temperature drop of EGT's through the turbo of around 150 - 200 degrees or so. This means that if your safe egt's pre turbo would have been, say 650, you must now watch for a peak (sustained) temp of 450 - 500
Disclosure: I do install the Madman kits (amongst other things)
