Evershower
BillyH
Evershower
Post by BillyH »
Love good design and this is a great piece of kit.
You cannot believe the pressure one gets from an 8L/min submersible pump and it does what it says on the tin - Shower in 3 litres of water.
The only downside is the water temperature drops from 50° - 25°in about 3 mins so ideally, it has to be connected to a gas geyser so the shower becomes a 2 man operation with the second party switching on the geyser for a few seconds every 30 seconds.
Would be wonderful if the Kwikot's/Dewhot's of the world would create a constant temperature geyser that could be run from a submersible pump - And who needs water hotter than 45°
Would also have been wonderful for the now defunct (Thanks Manny) river trip :(
Membership # 0373 since 21 May 2015
You quickly learn to shower in 5 liters or less when you are in remote areas and water supply is perfectly worked out to last.
We did it a few times on our trips into the Namibian dunes.
I like those submersible pumps. They don't take up much packing space either.
Water temps? Well. Jerry cans on the roof rack on a hot summers day in the dunes makes for a lovely shower later in the evening
Billy, you may need a shower on the Richtersveld trip or the Baboons challenge [emoji6]
Flipside
Has thanked: 16 times
Been thanked: 48 times
Post by Flipside »
A kettle of boiled water into the shower's supply will break all but the most extreme cold waters, and a 12v pump to get it to the shower head is all you need. never understood why people need complicated shower setups.
If you want to do it Larnie and a gas heated water supply is probably next best.
Flip
