My Patrol 4.5 Build
Douw
Has thanked: 17 times
Been thanked: 17 times
My Patrol 4.5 Build
Post by Douw »
Hi, guys.
Background:
In 1999, my father-in-law, Gregor, bought a beautiful Nissan patrol 4.5 petrol.
Last year October he gave me the 4.5 as he was scaling down on everything as he moved from his house into a nice retirement house.
I had plans of building a complete off-road rock-crawling beast.
The Build:
I took the car to Anthony Forgey after speaking to Manny and Andreas.
I asked Anthony to pull out all the stops and install everything that would transform a standard 4.5 patrol into an absolute 4x4 monster dream car.
His advice was that we get all the parts ready and then attack it all at once.
Good planning to maximize efficiency by opening the diffs once and installing everything to minimized costs and maximum use of labor use.
The plan (for maximum articulation and grip.):
37" Tires
4" Lift
Gear ratio reduction,
Suspension upgrade -
So the list started
1. Full Service (oils and filters).
2. Radiator repair & fan belts.
3. Air hoses.
4. Oil pipes.
3. Bonnet gas struts.
3. Additional fuel tank, with gauge and manual transfer pump.
4. Transfer case low range reduction to 4.3 ratio
5. Manual hub lockers.
6. Air lockers front and rear
7. Gear reduction for both diffs also 4.3
8. Steel rims with a changed offset
9. 37" Maxxis Tires
10. 4" Suspension lift - Raw
11. Bzt front and rear replacement bumpers
12. Adjustable rear trailing arms, adjustable panhard rod front, adjustable panhard rod rear, adjustable draglink, heavy duty swaybar links.
13. Chrome-moly tie rod with ball joints
14. Extended brake lines and breather lines
15. Propshaft balancing
16. Android radio with antennal and reverse camera
17. New Clutch kit
In February Anthony finished the car and we took it on its first test at Hennops
Afterwards the flex and other adjustments were made.
From Hennops on I have been impressed with the new Patrol - it gives me many smiles per mile. :D
Gregor:
Gregor's health was failing but I managed to take him on one last drive with the now big Patrol - he needed a two step ladder to get in! :D
The smile on his face alone was worth it all
Unfortunately, a week later. on the 30th of March this year Gregor passed away.
Going Forward:
Since then I sold my Land Cruiser 79 series pickup and the Land Cruiser Prado.
I bought another 4.8 Nissan Patrol for my daily driver which I am going to chop and transform into a pickup.
I will do a write-up on that once I am finished....
2023 FJ Landcruiser 4.0 L V6
1999 Nissan Patrol 4.5 L
2005 Nissan Patrol 4.8 L
Douw wrote:
Sun Jun 22, 2025 4:32 pm
What kind of Neanderthal sells a Cruiser to buy a Patrol?
I remember that fateful day well;
I took you & Andreas to lunch at Cesco's as I owed you both.
You told us about Gregor's Patrol & your plans.
You then asked who would be the best person for the project.
Andreas replied immediately "Forgey, Ant Forgey, he is the only guy"...
I think Ant now owes Andreas & I a lunch! :lol:
Trolly Fan
Has thanked: 37 times
Been thanked: 194 times
Post by Trolly Fan »
Sun Jun 22, 2025 4:38 pm
Those who finally see the light are few....
2005 TD42 "Masewa"
1996 TB48 "Skilpad"
1993 TB42 "Shortie"
1985 SD33 "Toro"
NINJA
Been thanked: 12 times
Post by NINJA »
Beautiful ride👍
Trolly Fan wrote:
Sun Jun 22, 2025 7:24 pm
The only light Paptrillers see is the 'Check Engine' light! :lol:
Patrol looking good.
Bugjuic
Has thanked: 246 times
Been thanked: 156 times
Post by Bugjuic »
Pragtige Patrol daai!!! Ek sou niks verander nie. Daai is soos die droom!
Trolly Fan
Sun Jun 22, 2025 8:04 pm
Petrol "paptrillers", for you yotaholics, only need to watch the fuel light coming on. :mrgreen:
Diesel "paptrillers", only need to watch the madman, for EGTs and water temps.
But everything else about it puts a smile on your face. :D
2005 TD42 "Masewa"
1996 TB48 "Skilpad"
1993 TB42 "Shortie"
1985 SD33 "Toro"
Kak comment, I should report you to a decent moderator like Ian.............
Love the project ❤️
Wanted to ask figures but I know costs as I did Crawler gears in Tiny Tiger 🐅 new setup.with Hilux tc
