SnoMaster Remote DIY
I was on-site on a project in Postmasberg and forgot the remote on the dash for the whole day where the Northern Cape sun completely trashed it. I arrived back at the truck to find the remote swollen and warped. Strangely enough, it still worked for a few months afterwards. But it no longer charged from either USB or solar and eventually died. I've not thought about it much and not used it for a few years...
Last week, I received a nice shipment of electronic goodies for some of the projects I am always busy with. And whilst putting them away and sorting out my electriconic component storage stuff, I came across the remote. I decided to butcher it.
Gathered the USB connection had broken off the circuit board, and the small PV panel attached to it so that one can charge from solar no longer works... And then the case looks absolutely horrible. Warped and broken. The face-plate for the remote was still in good nick though, so I removed it...
The following photograph is the front cover after removing the face plate. You can see it's not lekker...
Rummaging through my electronic components I hauled out a Lithium 1865 battery and an associated USB-C charge controller / battery protector.
I soldered the battery's + and - to the relevant points on the charge controller. I then desoldered the PV panel and the old battery from the remote control and soldered the output from the charge controller back to the remote's battery input. Voila. It looks like this in the case I printed (more on that in a bit).
I then knocked together a 3D design for a similar case - including space for the larger battery. The case did not come out perfectly on the front. I had to use build plate support for the 0.4mm depression for the remote's original face plate. This did not work fantastically and I had to resort to the dremel to remove some of it. No worries though, it will be hidden by the original face plate in any case.
Finally, I stuck on the original face plate, fired up my fridge and remote and tested. Works a charm. Clarification on the weird readings - I only run my fridge in the boot of the car when I use it so it has been off for a couple of days - hence the very high temperature (27 degrees). Also, the moment I plugged the fridge in to test the remote, the compressor started. Hence the 11.6V. The battery is good.
I've still got to design and print a back cover for the "new remote". But everything works again. It was a lekker simple project yesterday.
I also did a DIY a while back.
We buy cheap BT speakers for the pub. All of these things use a USB-C charging point which is the STUPIDEST thing to do when one considers that if the charge cable is connected, there is inevitable damage to the port due to even just the weight of the power supply and extension cord.
So I opened one up, drilled a hole for a DECENTLY CLEVER BIPOLE DC charger plug:
https://mm.digikey.com/Volume0/opasdata ... 5E2200.jpg
I disconnected the wires from the old fooked ISB port and soldered the wires correctly to the bipole jack.
Then connected my variable voltage power supply.
Very chuffed with myself, I flipped the switch.
Smoke came out of the circuit board.
Moral of the story? Don't feed a circuit 18v when it only wants 5vDC..................
Samaya
Been thanked: 32 times
Post by Samaya »
:lol: :lol: :lol: :lol: :lol:
If you had the time, you could probably repair the thing. Or just buy a new one... :mrgreen:
Samaya wrote:
Mon Oct 28, 2024 1:04 pm
Bought a new one. Circuit board was fried.
But I'll have the same issue again. Then I'll call Ian...........
Nice Ian. this remind me not to leave the Snowmasters remote on the dash. I do it from time to time with the solar side up to recharge.
Very nice fix. At least we now knows someone who can fix these remotes :D
Bugjuic
Has thanked: 246 times
Been thanked: 156 times
Post by Bugjuic »
Feels like a bit of a "design flaw"
I also had one bulge under heat, and swollen up, so much that the LCD just turned black, after few hours in the cold, all back to normal, but then WHY design it with a solar panel of it cannot withstand the heat. Anyway, it lasts forever and a day if charged up full, feels like a gimmick.
Nice writeup.
Just don't leave your nice expensive smart phone on the dash.........then we can discuss design flaws.
Guys, click here and complete the Application Form:
www.getalife.com.
Mon Oct 28, 2024 4:35 pm
www.getalife.com.
Isn't there a roof somewhere that you need to fix?
www.getalife.com.
Quoting to piss off Manny.
I reckon you need more cable ties...
Bugjuic
Post by Bugjuic »
jakeslouw wrote:
Mon Oct 28, 2024 2:59 pm
It never came out with a solar panel that is meant to be in the sun…
Bugjuic
Post by Bugjuic »
www.getalife.com.
That the place where they rejected you?
Bugjuic wrote:
Mon Oct 28, 2024 7:24 pm
No Peet, I think you are thinking of that Club of yours you suggested I join, they rejected me because I was straight...
Bugjuic
Post by Bugjuic »
:lol:
