Toyota 1VD V8 The Best 4x4 Engine Ever in SA ?
Has thanked: 108 times
Been thanked: 239 times
The 1VD V8 is available in a few different configurations. Single turbo, twin turbo and the marine version.
150kW @ 430Nm for the Single turbo
210kW @ 650Nm for the twin turbo.
272kW @ 650Nm Marine version.
Nodular Graphite Iron which is way stronger than normal cast iron and aluminium engine blocks.
Four bolt mains with an added stiffener plate making it theoretical a 6 bolt main bearing cap. This type of main cap lay out is only to be found on high end performance engines.
The list goes on. Forged crank, steel conrods with added knock pins on the caps, pistons with cooling channels cast in.
DOHC 32 valve heads with two level cooling jackets. Additional cooling jackets to keep EGT down.
Added scavenger pump to drain turbo.
Off the shelve kits making the single turbo producing 300kW an 1100Nm.
The Aussies build a 1000hp dragster with a 1vd V8 doing 0-200 in under 5 seconds.
Racing them in different diesel classes in Australia.
Quite a few samples running in SA with 500k km plus on the clock still with original injectors.
Farmers favourite for heavy towing.
Robust electronics that never fail.
Only time will tell if the 2.8 will dethrone it in the coming years, :lol:
Has thanked: 182 times
Been thanked: 237 times
But it’s diesel!
AndreasR wrote:
Thu Aug 22, 2024 3:37 pm
But it’s diesel!
Should have put diesel in the heading. :D
The other day I were thinking about Diesel VS Petrol. Petrol just don`t care how hard you work it.
No EGT and all that other stuff to worry about. You can moer it as long and as hard as you like :lol:
Has thanked: 742 times
Been thanked: 1277 times
Then Toyota took the 1VD, cut two cylinders off to make it a V6.
They moved the turbos & manifolds to make it a 'Hot V'.
It's in the Land Cruiser 300 as the V6 3.3 Twin Turbo diesel.
Making 225kW and around 700Nm.
The F33A was born!!!
Woolf
Has thanked: 33 times
Been thanked: 50 times
Post by Woolf »
Not the V8 but straight 6 1FZ used to build a hot 1/4 miler
https://www.youtube.com/watch?v=3q1ZuQH4K4U
https://www.youtube.com/watch?v=MSr6pI8QrJY
Thu Aug 22, 2024 5:12 pm
And everyone driving the V6 3.3 300 Series want their 200 Series V8 back. Read the forums. :lol:
Has thanked: 120 times
Some love them
Some don't
But tuned they make power
Has thanked: 225 times
Been thanked: 355 times
I'd happily own a 70 Series with a tuned TDV8
Has thanked: 292 times
Been thanked: 148 times
… the “New” 4.4L twin-turbo V8 petrol Defender
evidently brings 450 kW and 750 Nm of torque to play.
… just saying … dont know its Lang Dune etc record or aptitude…
We are talking 4x4s here Chas, there are many engines in BMWs and Metcs that produce lots of power.
Here we are talking about reliable engines fitted to 4x4s...
Not V8's in Defenders and other "Platkarre"...
Thu Aug 29, 2024 10:22 pm
... more Toyota KakPraat ... again !
No real factual background wrt
New Defenders 'non-capability or unreliability'
to date or likely .
Let alone Dune-ability.
Six bolt mains as said. :lol:
PsyPhin
Has thanked: 94 times
Been thanked: 138 times
Post by PsyPhin »
Why do you specify SA?
What engine is in your mind as the best in the world?
PsyPhin wrote:
Thu Sep 19, 2024 2:04 pm
Defender TDV6. Explosive!!!!
Unfortunately we does not have the huge engines they have in countries like the USA that produces a 1000Nm in stock trim. Also some of the most powerful and reliable engines from other countries.
That is the reason why I said South Africa.
The 1VD V8 made its name as a very good tow vehicle in both the 70 Series and 200 Land Cruisers. The torque available at very low rpm makes it one of the best 4x4`s available in slow 4x4 work.
There are many 1VD V8`s around that have done 500k km plus. Most still with their factory injectors fitted.
For the guys that love to modify it is one of the best base engines that due to its solid build and nodular graphite iron block.
