Gizzu 518Wh Portable Power Station with 3 Prong SA Plug Point
CornellMans
Has thanked: 12 times
Post by CornellMans »
Does anybody have any experience with the Gizzu 518Wh Portable Power Station? I'm thinking of getting one to use during power outages to keep working and also double as power when camping off grid for a night or 2 (coupled with small solar panel)?
The Gizzu Portable Power Station offers power on the go in a compact design. This portable power station is ideal for emergency needs, power outages, camping trips, or whatever else electricity is needed as it allows you to power up small appliances. With three USB ports and a PD port, you can keep your phone, tablet, notebook, and camera charged.
Thanks to the 230V South African plug, two DC ports, and one 12V auxiliary power outlet, you can power your mini-fridge, internet router, lightbulbs, and other small electronics and appliances with ease. This rechargeable battery-powered model features a robust design, built-in LED flashlight, and has three methods of charging, including car charging, solar power charging, and traditional wall charging.
Get off the grid and enjoy the great outdoors while keeping your essential gear powered & charged. With four USB ports including one USB 3.0 Quick Charge port and a PD port, this household essential is ideal in the event of a power outage or load-shedding allowing you to power up devices such as your router, TV, notebook, and other small appliances.
Features :
- 518Wh
- 500W Power Output
- Lithium-Ion Battery Technology
- LED Flashlight
- Powers Various Small Appliances and Devices
- Portable Wherever and Whenever You Need It
- Ideal Power Solution for Power Outages
- Supports Solar Charging (Solar Panels sold separately)
- Rugged Design
Specifications :
- Battery Capacity: 140000mAh / 518Wh Lithium-Ion
- PD Input/Output: 5V/3A, 9V/3A, 12V/3A, 15V/3A, 20V/2.25A
- USB QC 3.0 Output: 5V/3A, 9V/2A, 12V/1.5A
- USB Output 2/3: 5V/3.1A (Single Port 2.4A Max)
- DC Output: 12V/12A (Single Port 10A Max)
- AC Output: 230V/50Hz/500W (Single Port)
- Lifespan: 1000 Charging Cycles
- Protection Features:
* Short-Circuit Protection
* Over-Current Protection
* Over-Voltage Protection
* Under-Voltage Protection
* Over-Load Protection
* Temperature Protection
- Charging Times:
* AC Adapter: 24V/3A (9.5hrs)
* DC Car Charger: 12V (16hrs)
* DC Solar Panel: 60W (9.5hrs)
* PD Port: 45W (12.5hrs)
* AC Adapter + PD Port: 24V/2.5A + 45W (5.5hrs)
- Estimated Recharges:
* Smart Phone (3500mAh): 40
* Tablet (7000mAh): 20
* Portable Speaker (7500mAh): 18
* Action Camera (1250mAh): 112
* Head Lamp (2200mAh): 63
- Estimated Runtime:
* Laptop (50W): 10 hrs
* Lightbulb (11W): 46 hrs
* Internet Router (12W): 43 hrs
* 42? LED TV (100W): 5 hrs
* Portable Fridge (100W): 5 hrs
- Dimensions: 26.4 x 23.4 x 16.3 cm
- Weight: 5140g
What's in the box
1 x Gizzu 518Wh Portable Power Station
1 x AC Adapter
1 x 12V Car Charger Cable
1 x 2-in-1USB Charging Cable
1 x Accessory Storage Pouch
1 x User Manual
https://www.takealot.com/gizzu-518wh-po ... ID73887357
Wilderness 310
I've never heard of it - seems no one else has heard of it either....
CornellMans
Thanks, you can delete the thread
Wilderness 310
Has thanked: 230 times
Been thanked: 360 times
I'd buy from Ellies. Known products with decent support.
https://www.ellies.co.za/product/500wh- ... r-station/
Cornel … dont know the brand though appears
battery is bit on small side 518 Wh, though its
size and weight are probly make lighter & make
it more portable and, as a Li-ion, it probly charges
faster.
If its your first aux battery/Load-Shed stand-by I would
use a battery thats the same as your main car battery,
even if its Pb-Acid.
If a versatile 2nd Aux battery, which Im looking at,
definitely a Li-ion battery … Blue Nova, Hubble etc ? …
