Regulator, O' Regulator, where art thou ?
On my Conqueror Trailer I have a 5kg gas bottle.
This is plumbed, through the wall, to my cheap Cadac 2 plate stove.
There is no regulator in the system.
The Cadac works well.
When I bought it, it was branded LP.
Everyone told me it stood for LP Gas.
I'm 99% sure it was for Low Pressure.
I decided to upgrade & bought a new Cadac deluxe 2 plate stove.
The new one can run on SA LPG, Butane etc. etc.
The new one comes with a regulator.
I'm a bit confiussed as to why the old one needed no regulator & the new one does.
I assumed that the 3 & 5 kg bottles are too low pressure to need regulators while the 9kg up, which have bigger outlets do.
I called Andre Strauss as he is an overlander, 4x4'er, Plumber & Gas installer & asked him.
Trust me - he has no idea why the old one was happy with no regulator.
Anyone have an idea?.
Liquid, Petroleum, Gas ... ???
Woolf
Has thanked: 34 times
Been thanked: 51 times
Post by Woolf »
Doesn't answer your question but LPG=liquefied petroleum gas
I see Chas answered while I was typing
Cadac prefer to use jets to regulate gas flow. All Cadac skottel braais, burners and other stuff is regulated via a jet in the feed to the equipment.
Most other manufacturers uses regulators.
So in your Cadac system there would be a jet somewhere
Flipside
Has thanked: 16 times
Been thanked: 46 times
Post by Flipside »
Grips has the correct answer. The older burners had a jet where the burner’s knob opened the gas flow, it limited the gas flow.
Remember the little metal ring you had on a gas lamp and heater? That helped to mix the air gas volume for optimal burn.
Flip
Thanks guys.
So the Jet did the job of a regulator hence LP.
Kind of what I suspected but wasnt sure.
I'll fit the regulator with the new one.
Cheers!
ErnoKappRIP 20/11/24
Has thanked: 7 times
Been thanked: 11 times
Post by ErnoKappRIP 20/11/24 »
Of jy kan net braai 💁‍♂️
Erno, I mainly use the stove to boil water, it's a bit slower if you have to make a fire everytime...
Wed Nov 17, 2021 9:14 pm
One day, you will tell me something I don't know.
Fri Nov 19, 2021 12:37 pm
… guess you need a regulator …
