KZN Friends
Has thanked: 71 times
Been thanked: 145 times
KZN Friends
Going down to Amamzintoti 3-7 February with the Treg for a breakaway
Might first go to Balito then Accomodation Amamzintoti and Go to Port Edward side
Any worth whe possible sight seeing places to stop past on the Drive down and up
Even a off the beaten Route mountain pass
Down there
Has thanked: 453 times
Been thanked: 890 times
What?
Has thanked: 242 times
It depends on your time and intent, stop over at Green Lantern then head North on the 561 & down the escarpment... end up # Ladysmith or beyond,
then henceforth?
Has thanked: 193 times
Been thanked: 54 times
Normandien pass near Memel
There is also a lesser know pass Bezuidenhoud pass but may be bit overgrown as I believe it is not often used. I will go look in my stash of files.
Between Pietermaritzburg and Durban there are Killarney 4x4 and Monteseel Adventures
Has thanked: 318 times
Been thanked: 27 times
Toti waterfall trip. Try get a local down there to guide you. Nothing hectic if you stay on trail. There is play space if you want. Otherwise stay on trail . Also depends if trail has been used frequently , might be overgrown at places ???
HenriSteyn wrote:
Sun Jan 17, 2021 7:50 pm
I actually done that pass South to North 2018
It was the actual Oxwagon trail
Very overgrown
Lots of gates to open and close
But worth the views
Has thanked: 10 times
Been thanked: 37 times
Sat Jan 16, 2021 10:49 pm
What?
Back to the future
