Who's is the biggest?
Has thanked: 781 times
Been thanked: 1313 times
Vehicles keep getting bigger.
The bigger the better? or is it?
On a trail - big means beached or bashed.
Overlanding, big is nice, but fitting under trees or driving in existing tracks can be difficult.
Personally, I feel our vehicles. particularly Double Cab Bakkies (the most popular model) are starting to get too big.
The current Isuzu KB-6/D-Max in SA is 5295mm long & 1860mm long.
My daily drive is the old KB5 & it is significantly smaller that the KB-6/D-max.
To me, the current D-Max is a tad too big & I'd not want to go any bigger.
Kurt & I drew up a system a few years back called the 'Gerber' system, it took Length (Excluding Tow Bar) x Width (excluding mirrors) to give a 'Shadow area' in m2...
To give you an idea, the World Famous Fearless has a Shadow area of 8.66m2.
A Land Cruiser 200, by comparison, has a shadow area of 9.75m2
So, clearly anything over 9m2 is BIG... but what if vehicles start breaking 10m2? :shock: :o :?
Fearless 4705mm x 1840mm
8.66m2
Land Cruiser 200 4950mm x 1970mm
9.75mm
Current KB-6/D-Max 5295mm x 1860mm
9.85mm
2021 D-Max 5285mm x 1870mm
9.88mm
Current Hilux GD 5335mm x 1855mm
9.90m2
Ford Ranger (not the Raptor) 5354mm x 1860mm
9.96mm
VW Amarok 5254mm x 1944mm
10.21mm
New GWM P-Series 5410mm x 1934mm
10.45m2 !!!
For Chas,
Land Rover Defender 110 4785mm x 1790mm
8.66m2
New Defender 110 4758mm x 2008mm
9.55mm
Land Rover Defender 130 5063mm x 1790mm
10.07m2
Glad Isuzu has kept is size growth under control.
Notice how the new vehicles are getting wider, rather than longer...
Renier_c
Been thanked: 11 times
Post by Renier_c »
And the H3?
Renier_c
Post by Renier_c »
Old Defender 110 is the same size as Fearless! Wow
Renier_c wrote:
Sat Dec 12, 2020 3:50 pm
And the H3?
Hummer H3 4778mm x 1897mm
9.06m2
Shorter & Narrower than a Disco4, in fact, the H3 is only 11cm longer than an FJ Cruiser & is slightly narrower...
Has thanked: 466 times
Been thanked: 116 times
Pajero LWB
4,900x1,875 = 9,187
She is Beeeg!
One of the BIGGEST SUV's you can buy is the Lincoln Navigator.
5647mm x 2.030mm = 11.45m2 shadow,
I'd say, stick to something under 2.00m wide (excl mirrors) & with a shadow of under 10.0m2...
The UTE’s. Are they measured with or without canopies?
Obviously without canopies.
Excludes Mirrors.
Excludes Tow bar.
But most canopies would make no difference to the Length & Width.
You didn’t take height into consideration
Area is Length x Width.
Volume is Length x Width x Height.
Mike Nel wrote:You didn’t take height into consideration
Dumbass [emoji1787]
