4X4 on a budget
- Has thanked: 610 times
- Been thanked: 256 times
4X4 on a budget
Two blokes (Shauno and Jocko) have bought each other a cheap 4WD, and they've got to build it up for under $5,000(AUS) in less than 24 hours. (Part1)
https://www.youtube.com/watch?v=BrPSYAtTt84
- Has thanked: 784 times
- Been thanked: 1315 times
XJ... no question...XJ Junkie wrote:So what’s the best 4x4 for R50k in SA?
I agree, something like this:
https://www.namcars.net/Jeep-Cherokee-4 ... 1400699808
Although I doubt that you will be able to get one in good enough nick for 50k.
- XJ Junkie
The one Ricoffy posted is a very old pre-facelift one with nearly 300kkm, for R80k [emoji102].
I don’t think you’ll find a decent XJ for R50k anymore.
- XJ Junkie
Here is an option.
Some of them had a Merc 3.2 I6 motor with 162 kw & 312 Nm. That’s pretty powerful.
They are a bit low & don’t have a great ground clearance, but they’re as cheap as chips.
XJ Junkie wrote:The one Ricoffy posted is a very old pre-facelift one with nearly 300kkm, for R80k [emoji102].
They area lot more affordable than you two think.
I'll post a few for under R80k
Going rate is R45 to R60k
Here's one...
R45k
R45k
Here's another two...
R50k & R60k respectively
There's a brick behind the front wheel of the XJ advertised for 45k. I would stay away from that one
- grips
- Has thanked: 110 times
- Been thanked: 242 times
Suzuki SJ410. See a few available for around R50k.
I am convinced that a R50k 4x4 would cost you another R50k to get it reliable. Would then rather spend R100k from the start.
- Has thanked: 11 times
- Been thanked: 42 times
Their handbrakes never work. I tried for years to get my XJ's one to work. It will hold on a downhill, but not on an uphill. I used to forget about the handbrake and just put it in Park.
