Show your vehicle’s flex
#76
Most extreme flex
david bfreesani
#77
Post by david bfreesani »
Sani flex now on coils in the front. Still a bit to go, if I can just find a spot to flex him out all the way.
#78
Flex is old school[emoji1787]Fit double lockers and flex goes out the back door...
Joking. But my view around 4x4's have changed a lot the last few years.
If I have to build a 4x4 now lots of things will change.
Have crawled out a Dune this past week near Kleinzee which few 4x4's could make at full power thanks to double lockers.
In situations like this fflex is useless...
#79
That's impressive David.
For most of us, a lift of 25mm to 75mm is more than enough added flex.*
* Except Jeeps that need over 100mm of added flex to be Off-Road Rated...
#80
Hi all, playing at Hennop's 4x4, this is flex.
david bfreesani
#81
Sun Jan 03, 2021 4:26 pm
Flex is just something that came with the Patrol coil setup up front, and will just get better when I get to the coils at the back. My leafs are taking a beating in this sand. I can see how the rear end is suddenly sagging, and the leafs are looking bad. I can only think it has something to do with the amount of power it takes to get through this sand, and the heavy towing that I do in LR in this sand. And very little is towing a load on the ball, but rather dragging vehicles out that get stuck.
My test I did with the crawling in the sand did show me how well the 40 year old LSD is still performing, which I am super impressed with. Not once did it even look like it lost torque to one of the wheels.
#82
With tyre pressures in the region of 0.6 to 0.8 you reduce forces on drive train as you are driving on top of the sand.
Maybe it is a good idea to invest in a compressor.
The day will come that you will find yourself in a situation where crawling will not get you out and your only solution will be to deflate.
I bet if I dug in a Cruiser in soft sand you will not move me with 1.8 tyres.
Used my winch to recover a Corolla last Saturday on my way to the West Coast. The Cruiser just dug in with both lockers locked.
But we are going off topic. ImageImage
#83
Still around
johnoosthuizen
#84
Post by johnoosthuizen »
johnoosthuizen wrote:Lada flex ImageImage
Sent from my H3311 using Tapatalk
Rear axle 5 link flexImage
Sent from my LG-K520 using Tapatalk
#85
Martin de Jager wrote:
Sun Jan 03, 2021 6:31 pm
If you remove (or disconnect) the front anti-roll bar, then your wheels would all be on the ground in the first 2 pics.
#86
... with standard suspension ...
#87
Wed Feb 10, 2021 3:34 pm
Definitely not standard suspension
johnoosthuizen
#88
BushWacker wrote:... with standard suspension ...
Standard suspension and open diffImage
#89
Saxj wrote:
Thu Feb 11, 2021 9:54 am
https://www.landyonline.co.za/techtalk/ ... lation.htm
... though I recall us all trying that ramp
at Moegatle ...
... and the Rubicon was highest 1 wheel up
... but that wasnt really standard as it
had ( a quick ) release of its roll bar ...
... we should make the rule:
Goose Neck test
then
Ramp Flex test
with no adjustments /modifications ...
Ginger
#90
Post by Ginger »
I will drive it up something over the weekend. The suspension was changed quite a bit after this pic was taken
