Camping bits. Show off what you made.
- Martin de Jager
- Has thanked: 47 times
- Been thanked: 157 times
thanks Paul,
- Martin de Jager
thanks Andreas,
So I finished the drawer...
- Has thanked: 804 times
- Been thanked: 1347 times
- Martin de Jager
this past weekend we tried and experienced our trailer, plan come together, average consumption for my entire trip at 110km/h 8.19km/l, tows really easy.
Thanks Manny!
Well done Martin!
Well done Martin!
- Brandon
I've spent the year kitting out my bakkie.
This is my progress.
https://ibb.co/wp77LpM
https://ibb.co/37XxdX9
https://ibb.co/LCCXSXy
https://ibb.co/F08N0j0
https://ibb.co/RYSqn2B
https://ibb.co/gwY63jw
https://ibb.co/19xqZhw
https://ibb.co/9yn0b45
https://ibb.co/K99gWTn
https://ibb.co/HHrq4Sx
https://ibb.co/TL9h8Hg
- Chris Stoffel
If you made it yourself it counts. Yes. Not bad for a novice!
Suzuki Jimny - Hobbit Car
- Brandon
Plummed my 40L tank, so now have ample drinking water with either gravity feed or the option of a pump for high pressure. Tank is refillable insitu.
Sent from my MHA-L29 using Tapatalk
- Has thanked: 298 times
- Been thanked: 151 times
... yes ... best to have gravity feed from bottom
of tank in addition to pump setup as pump may pack-up on long trip ... and also good to empty tank completely from time to time etc
- Paul#25
- Has thanked: 381 times
- Been thanked: 283 times
Finished fitting the hinges and legs to the solar panel The 10m power lead is made up with the correct plugs to connect into the caravan. Now to finish wiring the caravan.
- Martin de Jager
Paul looks good,
