Which manufacturers fit factory recovery points?
I don't need to buy vehicles with recovery points - I breed them.
In about four years time my boys will have the pleasure of pushing my 4x4 out of the mud/sand. Until then, I try and keep the missus fit and strong.
Sal mens die kan gebruik as recovery punt?Image
It looks lethal. It appears that it’s a modified nut screwed onto a bolt?
It’s also not in line or connected to chassis.
#49
70kN
Fitted to solid bumper. Bumper fitted to chassis on 4 points, with 16 x 14mm rated bolts
#50
I don't know what FLP means.
Feeling Lucky Punk ?
Funny Looking parents?
Is is a Safe working Load rating of a maximum load rating?
Either way.... depends on how thick that plate is and what size the bolt head is on the other side....
FLP - Fairly Lethal Projectile
#52
Apocalypse wrote:I don't know what FLP means.
[emoji1787]
8mm wallthickness, 32mm bolt head
#53
Reenen wrote:
Sat Jul 27, 2019 12:47 pm
You bolted a piece of battle ship to your bakkie? [emoji15]
#54
Thinner, and the sparewheel carrier misform it.
Prof
Has thanked: 15 times
Been thanked: 19 times
#55
Post by Prof »
As Neil pointed out, the off set will be a problem (potential problem)
#56
Prof wrote:As Neil pointed out, the off set will be a problem (potential problem)
Hy is op 2 buite kante vas, en dan op nog 2 plekke binne toe.
Niks gaan die stuk staal af ruk.
#57
Probleem met eye bolts hulle is ontwerp om krag in `n reguit lyn te hanteer. Daardie eye bolt eintlik eye nut op jou bumper kom van oorhoofse lyne.
Ek het duisende van hulle gebruik die jare toe ek nog lyne gebou het.
henris
Has thanked: 3 times
#58
Post by henris »
I don't trust anything that comes stock on the chassis.
Saw one on a '79 LC the other day that was ripped open. The old type of hook, with the plate behind it to keep the sling from falling out, was also bent open. So yes. Please fit something that will survive a 10tonne snatch.
#59
henris wrote:I don't trust anything that comes stock on the chassis.
Soos myne
Prof
#60
Post by Prof »
Reenen, my eks het my Meganika boeke wegggemoer (sy was kwaad.....)
...maar as offset is die verspreiding van kragte on-eweredig. dus meeste krag (of bv 2 derdes) gaan na kant naaste aan punt en dus belading op daai boute gaan groter wees.
Maar ons weet in die werklike wereld doen ons tot dit breek... :P
