Some of my Projects and Toys...... Fire bus Project
Ricoffy wrote:Pierre, dit lyk na 'n bephokte projek.
Gaan jy die enjin stock hou?
Yip stock 2L Golf long block AGG want AGG engine code het n slight beter lower torq curve as ADY engine code
En gebruik Factory MP9 efi computer system wat op eerste Golf 3 GTIs gebruik was
Woolf wrote:Pierre is that the V6 which turns opposite to how it normally runs?
If so please tell us more about it and how its done
No that was an Autovilla which I sold to a guy in Shelly beach...
Saxj wrote:Bugger, what quarter mile time are you aiming for with the Autovilla?
0-100 in a eye wink
The ide of the short ratio transmission is for drivability and stying in the power curve all the time
Especially 4th gear doing 100km/h at 4000rpm I should drive up hills without a million gear changes...
Leon wrote:Pierre geniet jou omboujng dit is n kwaai motorhome daai
Dankie
Yip ek het lank gesoek vir n T3 Microbus Autovilla want hulle raak skaars en baie grooter binne as die Skillie Villas...
Just a few Pics of Elvis
Renay's 1966 Factory fitted sunroof Type 3 Square back
Very close to completion
1915cc Duel carb engine
Long Ratio transmission
Factory discbrakes from a 1971 model
Just some carpeting and a few items on the to do list
Then test drive time ImageImage
.Image
Renier_c
Been thanked: 11 times
#52
Post by Renier_c »
Lyk baie mooi...
#53
Netjies....
Has thanked: 376 times
Been thanked: 38 times
#54
Baie neties Pierre
Quick update on the Autovilla
Golf motor and diff lock transmission fitted
Power steering,Aircon with Heating ability and larger fuel tank fitted
Bought a front nose section to repair the parts that was cut out for the previous Radiator that was fitted
The front have been re welded back back to std
Radiator and Ac condensor now fit as std inside the nose panel
Still sanding and prepping nose to re paint the whole front cab
But drove the Autovilla to the Exhaust shop to fit a complete stainless steel system with 2 large silencers to make it super quite exhaust tone
Ac tested and heater tested working great
#56
Brilliant stuff Bugger.
Nice Thread....
Baie dankie my oom
Might be ready for the Marekele trip....
#58
Baie netjies Pierre.
Ek is jaloers!
Ricoffy wrote:Baie netjies Pierre.
Ek is jaloers!
You do not need to be Jelous
Still working on the project
Was nearly ready for Marakele national park
So using the Syncro and Junior the new addition to the family
Marakele national park August 2021ImageImageImageImage
