Dunes kills Jimny`s. I have seen Jimny`s in action on many dune trips they lack power and torque. At Waterford a stock Jimny won`t get on top of 50% of the dunes.
The Great Wrangler Debate...
- grips
- Has thanked: 110 times
- Been thanked: 242 times
- grips
Dune competition finals Whoooopa 2017. The Jimny was not in the competition fell out earlier. The owner wanted to make a statement during the finals. Look at his runup. This one with a 1800cc engine mod and lockers. He could not make it to the top with several runs.
https://www.youtube.com/watch?v=f4uwA-BfzWU
- david bfreesani
- Has thanked: 11 times
- Been thanked: 42 times
@Reenen, besides dunesSaxj wrote: ↑Mon Nov 04, 2019 11:36 amPower and Torque mean bugger all off-road, except in the dunes - What counts off-road is tyre size, and that is where the Jeep has the advantage, kits are readily available to lift it to be able to fit stupidly big tyres.Ricoffy wrote: ↑Thu Oct 10, 2019 6:20 amI'll wager that the Wrangler will kick the Jimny in the teeth when it comes to power and torque on any obstacle. It will always have the edge on any 4x4 trail. Rather compare the jimny to that Fiat Renegade.
Manny summed it up about right.
If you had to choose a vehicle in the Jeep category, buy the Everest/MUX/Fortuner. Better value for money.
In stock form the Jimny will run circles around a stock Wrangler. You are joking about Jimny vs Renegade, I hope.
- Has thanked: 785 times
- Been thanked: 1315 times
I'm with SAXJ here... on 99% of trails (not dunes) a Jimny will go where a Rubi goes.
I have, with my own eyes, seen Flipside and Victor (SAXJ) do it... many times.
But on obstacles like Koos se Klim the Jimny is at a slight disadvantage.
Remember it's about the power and torque to weight ratios in low range....
- ThysleRoux
Lower gears multiply power and torque ...........................
That video of Flip ripping his diff apart proves the point I tried to make earlier - momentum is the key - with insufficient torque you need speed to maintain momentum and speed breaks things. That diff called a halt because of the wheels losing and gaining traction due to the bouncing caused by SPEED !!!
I rest my case
FLEX is UNDERRATED
FLEX is UNDERRATED
- Has thanked: 610 times
- Been thanked: 256 times
You're opinion is baised. You thought the same of a Tuna vs Jeep.Mad Manny wrote: ↑Wed Nov 06, 2019 10:10 amI'm with SAXJ here... on 99% of trails (not dunes) a Jimny will go where a Rubi goes.
Koos se Klim is one of those exceptional obstacles, that without some sort of traction aid, it is exceptionally difficult to conquer. The cross axle is severe enough at that angle that even the most modified of vehicles lifts a wheel.
A conventional bakkie with rear diff-lock quite happily goes up with the correct amount of momentum.
An open diff vehicle has a seriously hard time, and as Flip found, because of the angle, it is very difficult to pick up enough speed (momentum) to get over the cross axle, and as Thys points out, the speed comes with other issues too.
You can have all the torque in the world, but if you don't have traction....
- Jeanvn
The main difference between a guy with a Jimny and a guy with a modded wrangler on a trail is that the guy with the Jimny is having more fun. [emoji39]
Sent from my SM-N960F using Tapatalk
105 Land Cruiser
Amabroekies v6
Amabroekies v6
- GarrethG
@Saxj
Bud if you willing to get a stock Jimny I’ll arrange a stock standard Jeep Wrangler and we do Barakah together.
- GarrethG
Keep in mind we are using stock standard 4x4’s as if they rolled off the floor, we don’t want to destroy them. Barakah has a few obstacles we can do in reverse.
Actually most places will work even easy stuff like Hobby park and Hennops. We can always take a more difficult line.
The reason I suggested The Gorge is there are some nice challenging obstacles, but they are mostly soil, so little chance of doing damage. The rocky river bed section is optional.GarrethG wrote: ↑Tue Jun 09, 2020 11:56 amKeep in mind we are using stock standard 4x4’s as if they rolled off the floor, we don’t want to destroy them. Barakah has a few obstacles we can do in reverse.
