Show Us Your Recovery Points
- ThysleRoux
Chris, met geweld kan jy jou vinger in jou hol afbreek. Met die regte shackle sal jy nie sommer die pin buig nie.
FLEX is UNDERRATED
FLEX is UNDERRATED
- Has thanked: 5 times
Ons almal weet mos nou al n tight fit is altyd beter...
- RynoB
My Amaroks front and rear recovery points
- Attachments
- Amarecover.JPG (7.77 KiB) Viewed 7653 times
VW Amarok V6
The best so far Ryno[emoji106][emoji106]
- Paul#25
- Has thanked: 381 times
- Been thanked: 283 times
Is that because it doesn't need recovery just a bit of a cool-down period? ? ? ? ? ?
- Chris Stoffel
Towing points. Can you snatch from those?
I will have to consult my member for a second opinion.
Suzuki Jimny - Hobbit Car
- Chris Stoffel
ThysleRoux wrote: ↑Thu May 24, 2018 11:01 amChris, met geweld kan jy jou vinger in jou hol afbreek. Met die regte shackle sal jy nie sommer die pin buig nie.
Ja OK.
Party van die recovery points kan mens inderdaad in jou hol afbreek.
- XJ Junkie
Chris, those broken shackles in your photo - none of them are rated.
Martin shackle pins won’t bend with those reccie points. Those will tear first.
That VW screw in jobbie isn’t a designated recovery point.
- Rabbiddog RIP 7/6/21
Standard D3 recovery points front and back and my winch. I don't know if you can attach stronger ones to a D3/4 as they are integrated into the chassis.
- Chris Stoffel
Pics?
- XJ Junkie
Those are tow points. Unrated, but very good.Rabbiddog wrote:Standard D3 recovery points front and back and my winch. I don't know if you can attach stronger ones to a D3/4 as they are integrated into the chassis.
The front ones get used a lot
- Has thanked: 6 times
Even the back ones get used their fare share, remember it is permanent 4wd[emoji12] and automatic[emoji12]XJ Junkie wrote:Those are tow points. Unrated, but very good.Rabbiddog wrote:Standard D3 recovery points front and back and my winch. I don't know if you can attach stronger ones to a D3/4 as they are integrated into the chassis.
What a life?!?
- Chris Stoffel
I reckon it would be in order to show my Samurai rear recovery points, seeing that my 'bek is so groot'.
Nice keyringChris Stoffel wrote:I reckon it would be in order to show my Samurai rear recovery points, seeing that my 'bek is so groot'.
What a life?!?
