Topic for discussion- Intercoolers
From another angle :
consider aircooler of face area 0.25m2
vs one of 0.5m2 face area
Smaller face area intercooler will need far higer air throughput to carry away the same heat as from the larger area intercooler ...
ie volume of air throughput and its velocity is important and after temps will be different but what counts is heat content carried away.
Also front mounted intercoolers have a fan
at low sppeds/revs ... but not all top
mounted I suspect?
Mike Nel wrote:
Thu Feb 06, 2020 2:17 pm
I believe the intercoolers on the Ford Ranger and Mazda BT 50 are also behind the front bumper
If there's no bonnet scoop it's probably infront beneath the radiator - or even behind it.
I see Reenen came up with a solution to the problem ASPW was referring to...
Mon Mar 02, 2020 12:38 pm
HAHAHAHA brilliant Manny. Or Reenen?
Reenen would never do that - he doesn't have a roof turbine lying around on his scrap yard.
