Life with Land Cruiser 76/79
rudi.hinze
Post by rudi.hinze »
grips wrote:Very nice setup Rudi I agree with Manny we need to see some more of that installation. The 76 Series sold in some Countries as the Prado had a coil suspension at the back.
I was offered one awhile ago, unfortunately it had no papers. Was thinking of converting the body into a Shorty.
I have an idea to set the track width of the rear axle with stock side shafts to do away with spacers. Maybe I should just build a sample diff and test it.
Will do.
To eliminate spacers, one could cast or machine a new rear hub with only the wheel mating flange closer to the edge (45mm outward from stock) eliminating the load on the studs. The rest stays the same and since the two bearings in the floater are sturdy, I think they will take an offset load. Cheaper than importing a whole fabricated longer housing and side shafts. Plain bolt-on solution that could work.
Check this from Aus:
https://youtu.be/uS6SFQmkfoE
rudi.hinze wrote:
Fri May 10, 2019 7:20 pm
Great minds think alike :lol:
rudi.hinze
[quote="grips"][quote=rudi.hinze post_id=12475 time=1557508804 user_id=322]Hahaha.
Build it oom and you can make a nice little business from it. Patent it and sell the rights to Toyota.
I will send you a sample of my U-bolt plate and u bolts I have designed for the rear leafs.
It adds some millimeters to ground clearance under the leaf pack
Hyades
Has thanked: 10 times
Been thanked: 3 times
Post by Hyades »
I wish they made an auto...
The Aussies install a GM auto box.
Here in SA is one such a conversion I know of.
rudi.hinze
grips wrote:I will send you a sample of my U-bolt plate and u bolts I have designed for the rear leafs.
Thanks oom. There is a market for the ubolt flip kit, seeing that it provides a smooth surface under the springs instead of the four bolts digging in.
rudi.hinze
grips wrote:The Aussies install a GM auto box.
Probably cheaper than putting a 200 series auto in too, with its own stand-alone shift computer.
Fri May 10, 2019 8:49 pm
Interesting video.
This Trutrack seems like a great option.
Would be interesting to see what the landed cost would be (Rudi).
But, my God, watching ASPW drone on in his irritating, wandering, repetitive, unstructured, laboured style is painful.
He could have said all that in less than 8 minutes, but I had to sit through over 16 excruciating minutes... :oops: .
Manny, will there ever be a day that you don’t bitch and moan about everything?
You ASPW fans are very defensive of your hero ....
Hyades wrote:
Sat May 11, 2019 8:44 am
Owning an auto cruiser would be like dating Caster.
Hyades
Post by Hyades »
Sun May 12, 2019 5:22 am
LOL nee jirre man! :D
rudi.hinze
Seems like I may just have gotten my grubby paws on a Trutrack system (should have it early next week). This has not been procured through the normal channels (read much cheaper) so if someone is really interested, let me know and convince me to rather sell this to you than to keep it for myself.
