bush pig trailer advice
Jadranko
Has thanked: 92 times
Been thanked: 154 times
Post by Jadranko »
Original right side (with gas bottle )and left side with kitchenette instead gas bottle.
Previously both were same.
Jadranko
Post by Jadranko »
. fridge with drawers in front and storage under the fridge accessible from opposite side only.
Jadranko
Post by Jadranko »
. kitchenette.
Every level is full extension drawer
Jadranko
Post by Jadranko »
Back door access storage.
It can be accessible from top but I find it non practical lifting tent and all.
Apologies for quality of photos.
jotto
Has thanked: 94 times
Been thanked: 114 times
Post by jotto »
Looking really good.
Jotto
Kammatech.co.za
Jadranko
Post by Jadranko »
thanks Jotto.
not really pretty but as simple as possible.
material used for build:
9mm ply wood
19x1.6 sq tube
30mm angle iron
19mm connect it
some screws and pop rivets.
only machined parts were panels for kitchen box ,1mm mild steel, everything else by hand and small power tools.
Very Nice Slav!
Jadranko
Post by Jadranko »
Last weekend project to store tent poles.
Until now poles were transported on top of the tent in a bag.
Diy aluminum door,75x75 PVC down pipe,latch and hinges.
Few plastic L brackets under and 2 diy aluminum clamps in a shape of 2 pipes when together securing everything to trailer frame.
In photos 1 and 2 previous owner great idea can be seen.In a same level as down pipe ,to the left, there is catering table in it's own pocket.
Table came with the trailer,all I did was to sand it down a little and give it some hammerite.
I made a similar thing using a 110mm plumbing pipe. I closed the one end using a plumbing stop end and the other end I fitted a plumbing collar with screw on stop end. So all plumbing stuff.
Jadranko
Post by Jadranko »
unfortunately i had no space for round pipe.75mm square fits just right and there are no 75mm square pvc plugs available.
back side is closed with polypropylene plugs for steel tubing.
slight modification was required.
Always nice to put your own touches on a vehicle
Look like a nice buy.
Hope you.make lots of memories with it
