New 2.8 Land Cruiser
Has thanked: 287 times
Been thanked: 327 times
jakeslouw wrote:
Fri Mar 15, 2024 10:35 am
Fri Mar 15, 2024 9:49 am
The main attraction is its auto.
If they brought out the V8 diesel in Auto the 2.8 wouldn't sell as well.
There was a conversion offered by somebody? Zone Offroad?
There's been a few such done in South Africa but at R150,000 - R250,000.
Here in Aus this is quite a popular conversion to place the 6 Speed AB60 Automatic Transmission from the 200 Series in the 70. Looking at around $20,000 - $25,000.
Now you can buy a 2.8 which in stock format has more torque than the V8. The 2.8 is cheaper, lighter on fuel and has the auto box. Now usually auto vs. manual comes down to user preference, but in this case the 5 speed manual in the V8 has a weak 5th gear and a lot of guys spend money on the manual as well. Nothing wrong with it. Cruisers are not known as value for money purchases, but I think the 2.8 makes the V8 look even more overprized.
Only the 4.2 with the R151 box had a fifth gear problem. All other Cruiser run H151 and H152 gearboxes. These are truck boxes that also do duty in Dyna trucks must be the strongest 4x4 gearbox available. You can tow in fifth gear with them as the 5th gear is on the main shaft. Manny guys do a 5th gear ratio change on them to bring down the rpm on the v8
Selling like soetkoek :D
Just buy Karin a LC 76 2.8 GD 6 already Christo....
And so it begins :lol:
Guy that I know very well one of the first to buy a 2.8GD6 79 SC Cruiser. One by G-Turbo kit from Australia on its way.
260kW and 840 nm on its way. Will report back.
Trolly Fan
Has thanked: 37 times
Been thanked: 191 times
Post by Trolly Fan »
Thu Aug 22, 2024 11:43 am
But how will it end.... :lol:
Making smaller engines sweat harder. I do not know.
2005 TD42 "Masewa"
1996 TB48 "Skilpad"
1993 TB42 "Shortie"
1985 SD33 "Toro"
Trolly Fan wrote:
Thu Aug 22, 2024 1:52 pm
The way the 1GD are designed makes it better for performance upgrades than many other large capacity older designs.
1. The block does not have piston liners to add structural strength.
2. Pistons do have special coating and cooling channels. Also floating pins with steel conrods.
3. Steel crank shaft. Main Bearings supported by upper and lower cases in which balancer shafts run.
4. 16 Valve double OHC with second level cooling ports to keep EGT down.
5. Trochoid gear driven two stage oil pump with extra oil squirters. Engine mounted oil cooler.
6.Intake manifold with pneumatic swirl control flaps to form a vortex controlling combustion.
7. On the ECU side two EGT sensors pre and post turbo to adjust fuel ratio to keep EGT in check.
Pretty robust design with many features only to be found in high performance engines.
Like the 1VD V8 seems it were designed with room for lots of extra horses.
Are you saying you oppose Nissan's decision to replace the 5.6liter V8 with a 3.5 V6 that produces more power & torque?
But the V6 has a turbo dummy. You can wring anything out of an engine with a few add ons, you can even get a diesel to be as good as a petrol, well…………..almost.
AndreasR wrote:
Thu Aug 22, 2024 6:19 pm
It has Two Turbos...
Trolly Fan
Thu Aug 22, 2024 5:06 pm
Not at all, but all other factors held equal (i.e. ignoring the stuff Grips listed on the 2.8 in post #22), a smaller engine I would think has less potential for upgrades than a bigger one. I have seen videos of the VK56 being supercharged in Oz, and look on the driver's face says it all. I do not think the 3.5V6 would have that same potential. But as with the 2.8 in Toyota, who knows, I may be wrong.
2005 TD42 "Masewa"
1996 TB48 "Skilpad"
1993 TB42 "Shortie"
1985 SD33 "Toro"
