Nissan Patrol 4.2 pickup
Has thanked: 781 times
Been thanked: 1313 times
Wed Aug 28, 2024 10:19 am
… reduces inlet air temp but also enriches the cylinder mix
for more power …
Thanks Chas, none of us knew what an Intercooler does... :roll:
Has thanked: 230 times
Been thanked: 360 times
Once you get past all the cooling issues on a Defender Puma, the spud shaft to the transfer case fails.
Wed Aug 28, 2024 10:54 am
for more power …
… even the exhausting Mannyfold ? :lol:
jakeslouw wrote:
Wed Aug 28, 2024 11:04 am
… maybe best to pre-empt this
by visiting Dr Ashcroft early on …
Jadranko
Has thanked: 89 times
Been thanked: 142 times
Post by Jadranko »
hmm,Intercooler does same job as beer.
Jadranko wrote:
Wed Aug 28, 2024 11:36 am
In that vein, is tequila considered ethanol injection?
Anthony Forgey
Has thanked: 70 times
Been thanked: 65 times
Post by Anthony Forgey »
I bought a non turbo TD42 patrol. It had 222k km on the clock. I added a turbo after about 1 year or 2. And around 272k km. I'm now at 400k km.
Key to keeping it from getting hot is a properly working cooling system. An appropriate sized intercooler and correct tuning. My car doesn't get hot. Normal cruising temps with the aircon on sit around 78 degrees. Towing the fully loaded camper trailer is around 83 degrees.
Max temp for the last few months was 100 degrees driving back from river trip (still loaded( up Modjadjies kloof at 100-110km/h GPS speed.
jakeslouw wrote:Well, this thread is moot because I had to buy a GeldWasMin as the Tata went to Bakkie Heaven.
But Reenen should know not to argue with Allknowing Grips. The fact that Reenen has turbo'd more TD27 and TD42 IDI engines than anybody else on this forum doesn't hold any merit to him.
jakeslouw wrote:
Wed Aug 28, 2024 9:19 am
Thanks for the Allknowing compliment :lol: Also I see no reason to argue with Reenen.
Also I go out on numerous 4x4 trips with lots of different 4x4`s. I see things happening around me.
Ek is nie hier om met enige iemand te baklei nie.
Al wat ek sê, ek het 3 heavy modified td42’s, 2 td27, en n Qd32ti, en n Rd28ti, almal heavy modified, sonder eft probleme. So ek sê net vir oom grips, wat nog nooit daarvan gehoor het, dit bestaan wel. Geen argumente, ek respekteer oom Grips ontsettend baie, en het ongelooflik baie by hom geleer.
BushWacker wrote:Ford Transit engines in Pumas also can get bit too hot & bothered under heavy load in Kalahari etc so the canny Landymen put a bigger intercooler in etc …
maybe Patrollers should try that ?
Bigger intercoolers is juis wat my egt’s opgelos het. Ek hardlooo die grootstes wat ek frontmount kan insit.
Anthony Forgey wrote:I bought a non turbo TD42 patrol. It had 222k km on the clock. I added a turbo after about 1 year or 2. And around 272k km. I'm now at 400k km.
Selfde ondervinding
Helfdte van my gu patrols het by Antz gedraai vir sy magic.
I don't understand this Thread:
Turbos to make it go.
Bigger Intercoolers to keep it cool.
EGT's to monitor?
None of this makes sense to us Toyota drivers.
We get in and drive.
Simple...
Quick question Manny. Is your Toyota mapped?
There are more mapped Toyotas on the road than stock.
Wed Aug 28, 2024 7:21 pm
EGT's to monitor?
Simple...
... much as I hate to say it
you are , unknowingly, delving on the real issue !
:lol: :lol: :lol:
AndreasR wrote:
Wed Aug 28, 2024 7:49 pm
... yes ... this is also a moot point ...
... I'm off to kip now,
but just to say ...
one can also put in bigger & better radiators ;
... for cool is cool ...
