Flopower 12v water pump???
PsyPhin wrote:
Mon Aug 18, 2025 11:50 am
now why is that one R600 vs R2300 for a FL35?Am I going to need to replace that in 2 years time?
At R600, who cares? That's half a tank of diesel.
PsyPhin
Has thanked: 109 times
Been thanked: 141 times
Post by PsyPhin »
Wave wrote:
Thu Sep 02, 2021 2:29 pm
Ok, with some help from Iron we have found the agents
Rudd Products in Kyalami 011-702-3010
The same pump is under different names; Surgeflo, Starflo, Singflo & Flopower, so probably some Chinese rubbish if it has so many names for the same thing
These people were very helpful, but unfortunately the pump is not repairable due to its age. They did try replacement parts but someone did a camp side fix and use the wrong screw stripping the threads and ruining the water proofing.
jotto
Has thanked: 94 times
Been thanked: 114 times
Post by jotto »
PsyPhin wrote:
Mon Aug 18, 2025 2:38 pm
Maybe we can help? We stock the Seaflow pumps and install them into our trailers. I can also add a separate water filter that will make life a lot easier.
Jotto
Kammatech.co.za
Jotto maybe you can give us some info on the filters
I saw this weekend at the Zwartkops 4x4 show a company had a 5 element filter system for the water system
Is that over kill or worth it
What can you supply
jotto
Post by jotto »
Bugger wrote:
Tue Sep 09, 2025 9:27 pm
What can you supply
We use inline filters, like the JoJo dual filters. The ones in the pic below work well, all depending on your space available. You can get them at Waterspot (https://waterspot.co.za/)
We use the single unit typically:
5 Filter system seems overkill, unless you want to draw water directly from a river or unknown source. More to break.
Jotto
Kammatech.co.za
Thank you for the info
I also thought the 5 filter system the guy had at the show was overkill
