Who's is the biggest?
Nico-MAD
Post by Nico-MAD »
Sat Dec 12, 2020 3:27 pm
Glad Isuzu has kept is size growth under control.
Notice how the new vehicles are getting wider, rather than longer...
And the width is a problem as we need to stop at a shopping center sometimes and their parking bays are getting narrower.
Sat Dec 12, 2020 9:36 pm
Area is Length x Width.
Volume is Length x Width x Height.
Glad you also attended school, now and again.
I understand where you guys ate coming from in terms of your measurements. But won’t it be a better comparison if the measurements are volume measurements?
It’ll please me tremendously if you could redo the calculations 🤣🤣🤣
As a shithot builder, I can inform you that the standard height of an opening is 2.10m.
Your standard garage or sliding door has a 2.10 floor to lintel height.
You do get a 'Caravan' garage door height, which gives you a DLO (Day light opening) of 2.30m.
My garage has a floor to lintel height of nearly 2.50m, but a DLO of 2.35m because the garage door restricts the aperture.
But I can pull the cord & force is back to get over 2.40m usable.
ALL vehicles you can generally buy & drive on a 'Code 8' or 'EB' License are under 2.10m high on date of purchase.
Obviously the Iveco Daily 4x4 & the Unimogs are much higher, but you can't drive them on a Code 8/EB license.
So comparing standard heights is pointless as all stock vehicles are well under 2.10m high.
It's also pointless as virtually no person keeps his height stock, they all do suspension lifts, add Roof racks, Roof Top Tents, fit Jerry cans & gas Bottles, fit Thule Roof Boots etc etc..
So, nice tangent Mike - but a pointless exercise...
Important parameter should be 'undervolume'
... Length*Width*ClearanceHeight
... and there 130 would likely prevail ,
... also with its PayLoad of 1.4 tons ?
What about the Ash Tray draw length and volume Chas and Mike?
If you want irrelevant measurements that should top your list...
I think it’s about time you lock this thread and suspend said members that dare come up with different ideas.
(T.I.C)
FlatEarthers like Manny don't deal in 3D Space...
and they're naive enough to compare
Kid-Carting Soft-Roaders with proven Camel Trophy Graduates like D1s and D2s ...
76 Land Cruiser 9.18
SWB Pajero Gen4 = 8.22
Jimny Gen3 = 5.83
Jimny Gen4 = 5.96
Just to compare the shorties to each other for interest sake.
CornellMans
Has thanked: 12 times
Post by CornellMans »
Sun Dec 13, 2020 9:02 pm
This chirp made my day!
Wilderness 310
... talking of height ... I popped outside and measured my tow-ball altitude ...
65 cm above ground level and SAB recommendation is a max of 46.5 cm,
... even moving to bottom slot of my drop-plate will only take me 8cm down,
... so will need another or make one with more slot positions ,
but then it’s going to be quite a constraining plough ... :o :o :o
CornellMans
@BushWacker : But you trailer is level when hooked, why do you want to drop your tow-ball? SAB is only a recommendation after all..?
Wilderness 310
... Level ?! ... my Mini-Met trailer is being towed like a VC at take off !
( ... even with the same/interchangeable 16” rims/tyres as the Defender.)
That’s what I need to address ... it should be towed slightly nose-down.
At least we've stayed on topic... :shock: :roll: :o
Mon Dec 14, 2020 1:17 pm
... ironically yes ... because the dimensional geometry of large vehicles affects key things like departure angles and turning circles etc and these are often further changed/compromised by later modifications such as
lifts, non-standard tyre sizes, bumpers, drop-plates, rim spacers etc etc !
Comes a stage when excessive size plus modifications etc are deemed less beneficial.
I seem to recall the 'Shadow' concept derives from the Bridgestone Trial Series 'Championships' courses unreasonably being laid out to the conspicuous advantage of small Jimnys etc and to the conspicuous disadvantage of large vehicles ... more tight turns and very close spaced poles and very few boulder beds, deep water drifts ... etc...etc ?
Departure angles, turning circles , clearances etc become very relevant in these circumstances.
