DIY Farm buggy
#106
Looking good, Richicory !
#107
Mon Jun 17, 2019 7:01 am
Oh, and before I forget, I have learned one valuable lesson: When you work out a budget for something like this, multiply it by two and then some! It easily becomes a deep and dark money pit.
Oh yeah.
thats the one lesson you learn the very hard way.
Have you kept track of your hours and worked out how much you could have billed by the way?
#108
Apocalypse wrote:
Mon Jun 17, 2019 10:54 am
Oh yeah.
I am ashamed to admit I have about 74 hours in thus far.
#109
Mon Jun 17, 2019 11:05 am
Oh yeah.
what is your hourly rate?
you could probably have bought a good late model bakkie by now !🤣
#110
Apocalypse wrote:
Mon Jun 17, 2019 6:11 pm
Oh yeah.
I could have gotten me one of these - If I worked for 74 hours, not paid any expenses, salaries nor tax :D
https://www.namcars.net/Land-Rover-Defe ... 1400687938
#111
I have build and rebuild my fair share of vehicles. Other than fun it does make no economical sense. Accurate book keeping on projects have show me on many occasions that one only remember the expensive items in a build. Fact is small things like bolts and nuts, hoses , paint and all that other little stuff that one tends to forget make up a huge amount of the project. Sometimes a surprising amount :D
#112
Bietjie off topic. Op die kostes van n rebuild/conversion.
Jy het n ouer voertuig met ou tegnologie engine. Jy sien n nuwer generasie engine, min of meer selfde displacement, baie na aan straight drop in in jou voertuig tipe engine, vir R16000 by importers.
Jy ag jouself effens handig, en besluit om die conversion aan te pak. Of, kry sommer net iemand om dit te doen. Dit is mos basies net n in en uit bout proses.
Kom ons haal arbeid uit, en kyk wat kos so n straight forward engine swop.
R16000. Engine
R7000. Engine management
R5000. Dyno tune
R8000. Radiator
R2000. Intercooler
R2500. Intake en turbo hoses
R1200. Air cleaner/housing
R3500. Clutch
R2000. Bellhousing
R600. Flywheel
R600. Power steering pomp
R800. Hydrolic hoses en fittings vir ps
R2500. Exhaust
R10-20000 vir nuts, bolts, fittings, engine mounts, onvoorsienne uitgawes
Skielik raak so n R16000 conversion vinnig duur.
En as jy tyd (joune of iemand wat dit laat doen) bygetel word, is die kostes deur die dak.
Baie mense vra baie keer of n conversion sin maak. Ekonomies: NEE. Terapeties: beslis
Jy doen nie hierdie build van jou om geld te spaar en jou skoonpa n guns te doen, jy doen dit as persoonlikke leer kurwe en “me time”. Om iets vir jou self te bewys.
Geniet dit, en well done. As iemand jou probeer ontmoedig, of dit af kraak, vra jou self af: wat het hy al gebou.
#113
Mooi gestel Reenen!!!
#114
Great comment Reenen, I completely agree.
#115
Reenen, ek stem saam en dit is goed gestel.
90% van die bou is maar net om te kyk of ek dit wel kan doen - en dit is besonders terapeuties vir die siel.
#116
Thu Jun 20, 2019 5:54 am
Jip, dit is daardie boudjies, moere, grinding discs en welding rods wat somtyds meer kos as wat mens aanvanklik gedink het.
Mad Manny wrote:Fortunately we have a Forum (& Club) member here who is a VW Guru.
Pierre 'Bugger' Eksteen of VDubTech.
He has just flown to Dar to do some work for a client, but he'll reply soon...
Ok only saw this thread now[emoji16]
Had a quick read through
Lekker to see the guys building toys
A few pointers
Wiring you must have the 2 Idiot lights working - oil light as suggested with a huge light on dash and very important the Generator/Alternator light also with a big light on dash
The importance of the Alternator light is that if the Fanbelt comes off the light will come on and indicate it is not changing
But more important is that the engine will have no cooling which cause overheating and engine damage as the cooling fan is attached on the Alternator shaft in the Fan housing - not good if you are alone deep in the veld
The offroad racing guys have fitted a bowl shape mesh over the back of the fan housing at the round air intake hole of the fan to keep grass and foreign matter out of the cooling fan
Did you come right with a master cylinder ?
If not you can buy a golf dual circuit one, fit a 20mm spacer between m/c and bulkhead
Modify pipes and supply and Bob's your uncle
Rear tyres try and fit the biggest and widest
Front a smaller and lower profile
This makes traction amazing
I did Baboons pass in a 2wd buggy when told it would be impossible
So yes it can go where a croozer can go and further - its proven
You welcome to give me a bell now and then if you need some help and advice +27826zero zero8663
On the carb check that the Small idling jet on the rhs of the carb is clear of dirt or it will not idle.
And give me that bell to explain how to set the auto choke
#118
Thanks Bugger.
#119
... thanks Bugger ...
... good constructive advice .
Was actually talking to someone today about wiring in a ‘+50A to -50A’ dial ammeter into my old Series 3 Landy , (even though they werent produced as standard items on them.)
He was warning to ensure I connect the ammeter ‘in series’ with the circuit I want to monitor (and not ‘in parallel’ like a voltmeter) and do so in such a way as to NOT include the high cranking current of the starter which would be excessive.
Also as its an alien part, so to speak, to make sure it can handle the output of the installed alternator etc
#120
Loadbin done.
