Bog Out Recovery System
Let’s discuss this topic, for Wayneman, and decide if we believe it to be a good option or not.
My thoughts are that it needs to be tested is way more hectic recovery situations to be considered effective but for easy recoveries like in this video, it doesn’t look too bad.
https://youtu.be/Tsc-CrYsSE4
Michael
Post by Michael »
Once it is wound around your wheel several times, I'm wondering how you get it off without backtracking back into the obstacle?
Been thanked: 249 times
One negative is the need for an anchor point.
I wonder how much strain that puts on the one wheel.
For "light" recoveries it can work, but with a seriously stuck vehicle you will put massive strain on one cv/uj, sideshaft and control arms. Imagine running off the thing and wrapping it around a drive shaft 😱
Quack
Post by Quack »
I’ve played woth a piece of rope all day long, trying to knot one!
Most rope will not have a tensile strength strong enough to allow you to do damage to the drivetrain, they will snap before you damage anything, which will leave you stuck as before![emoji1787]
What a life?!?😜
AndreasR wrote:One negative is the need for an anchor point.
With your superior wealth, just buy two and half the load [emoji2371]
Will only work on a 4x4 with traction control or lockers. Won`t move a vehicle with open diff`s.
The strap that goes through the rim stand a chance of being cut on certain vehicles where there is a few millimeters of clearance between the brake caliper and the rim.
Grips, correct me please if I’m wrong, but doesn’t a vehicle with open diffs start moving again if the one spinning wheel gains traction? And doesn’t this gadget simulate traction thereby causing that “spinning wheel” to gain false traction and then get the vehicle moving again, assuming you attach it to the wheel that has no traction?
It would be interesting to see this thing used in an older Jimny on a cross-axle obstacle.
I'm not a fan of these gimmicky things.
This will work but, in my view, it's;
* Only for a lone traveler or where others can't assist.
* Mainly for mud & very soft sand.
* Doubt you'll get more than a few uses out of it.
* Good luck packing it up after a mud extraction.
* How do you 'apply' it once you bogged in mud or deep sand? - won't be fun...
Sat Jan 18, 2020 8:08 am
Yes it will stop the spinning wheel but in mud and sand you will now transfer power to the other wheel and make that too spin. You will need two for an open diff.
I once broke a side shaft with a serious mud recovery constraining the spinning wheel with a steel grid.
