WMC Cappuccino in Bots- Inverter
Hi all fellow WMC 4x4 overlanders.
I wanted to reach out to our esteemed overlanding guru but i thought I would rather post here to get more Likes.
I enjoy cappuccinos, double shot ones. I intend to take my Saeco coffee machine with to Botswana end of this month else the trip would be dreadful (for the others who has to sit with my pms)
My Saeco uses 1850W, I intend to buy a 2500w pure sine inverter (which I will install in my Bushlapa later on) to drive the coffee machine from my Prado’s battery but while idling also.
Question: Will I damage my battery?
Been thanked: 249 times
Got no idea about your battery but I got to say I’m partial to the odd espresso myself so bring it along let’s test it.
Let me see if my answer helps you LesseW.
I don't drink Cappuccinos because, well, I'm straight.
However, I am also going to Bots & I was faced with a conundrum:
How do I take enough coffee to last the entire 17 day trip?
Now, most of you uncouth savages drink instant (& walk on laminate flooring), so you think the answer is to throw another tin of Ricoffy in the trailer.
However, we cultured individuals drink filter coffee and filter coffee tastes best when freshly ground..
I could grind 17 days worth of coffee before departure, but I'd far prefer freshly ground.
I did order a hand crank grinder - but it takes a full 5 minutes of hard labour to grind enough for one cup! :o :shock: :?
So, LesseW, I would greatly appreciate it if you bring a 2500W inverter - then I can grind some fresh beans every 2 or 3 days.
So to answer your question - yes, buy the inverter...
PS I take it you add a lowfat soy milk gently frothed to your cuppaqueerou...?
I enjoy it with Almond milk porra, but the Barista style version[emoji847]
LesseW wrote:
Thu Apr 07, 2022 8:20 pm
I enjoy it with Almond milk...
Almond Milk?
Almonds are nuts, right?
So you put Nut Milk in your coffee?
Figures.
Jip, it gives me radiant skin and almonds are good for the colon…..
You do get 12V Nespresso Machines.
Would be te easiest way out.
Driving cooking stuff powered by elements from inverters is not a nice idea.
Your inverter would have its best performance with a dedicated power source. Why risk you vehicle battery and charging system.
The best solution is Stroh does not need extra power sources [emoji23]
Almond Milk?
Figures.
[emoji1787][emoji1787][emoji1787][emoji1787]
12v Nespresso machine? I need to investigate.
Remove the hand crank and connect a cordless drill. Problem solved. :)
Wessel Wessel Wessel...
Wonder if he'll be taking a gourmet chef along as well [emoji848][emoji848][emoji848]
Shane wrote:
Fri Apr 08, 2022 9:59 am
I doubt it. Lessew wants to be the only pretty boy on the trip.
Well he'll fail dismally at that! [emoji848][emoji1787][emoji1787][emoji1787]
Willem: onthou, dis n double shot cappuccino, dis die manly version.
Shane: the following men are going with and from the list I feel I am Mr. Botswana: Manny, Andreas, Grips, Avon and Bugger[emoji16]
Gourmet chef, why not!
