Indeflate - brilliant product...
Has thanked: 743 times
Been thanked: 1277 times
As many of yopu know - I think the Indeflate is a great product.
Many people have never used it don't like it.
It is a simple, well made, high quality, robust, easy to use product that makes deflating & inflating quicker & easier.
It is the ONLY way you can inflate a tyre without the use of a pump.
What I like about it is that you don't have to crouch next to each wheel for a few minutes, you can stand upright & inflate/deflate.
Today I went to buy an Indeflate as a gift & to meet the Owner, Johan & his son, Rickus. - great guys.
The Indeflate retails for R1490.00 - they are in Radio St, Alberton North...
They also sell other great products - a compressor pipe & a pipe to connect to the spare (I have one) so you can check the spare & inflate/deflate it without removing it (great for vehicles where the spare is stored under the vehicle, rather than on the back door.)...
For more info, go to www.indeflate.co.za
Yip, brilliant products! I'm glad you convinced me to buy one too
Has thanked: 120 times
Been thanked: 239 times
Thanks for the info
After seeing Manny Use his kit at Bass Lake I ordered Pd and they personally deliverd my twin kit
I’ve used it. Good product.
Would I buy one for myself? Nope
Takes up a lot of space.
I would however like to test something Manny.
When we are in the Richtersveld.
Manual vs Indeflate.
Just a test for curiosity sake
The Indeflate is MUCH faster than the ARB type deflator where you crouch on the ground like a philistine & unscrew the valve.
Much much faster...
Is it the fastest in total work cycle time, from getting out the vehicle, getting the deflater, deflating & packing it away again?
It's faster than the valve removal option, but there are other deflaters that are faster than the Indeflate in toto.
Is it the most easy & comfortable to use? - No question.
Can any of the others inflate too? - not one...
Is connecting the compressor to each tyre (4 tyres) quicker than connecting the Indeflate to the tyres? - it's probably the same (total work cycle) but again, the Indeflate is easier & it's very easy to check the pressures as you pump.
I barely use the other deflaters anymore.
But it is not just about speed, the Indeflate beats others on:
* Accuracy
* Easy of use
* Comfort
* Range of uses/features (Inflates, Deflates, Balances, Incorporates Gauge, Can inflate without a pump).
As I say - I'm a huge fan of the product...
How can it inflate without a pump?
The same way as every other deflator, Bugger
Inflate
With out
A
Pump?
Has thanked: 182 times
Been thanked: 237 times
You can “steal” air from your spare it other tyres using the balance of pressure principle. Can’t see this being done too often but in an emergency it is just another feature that could be helpful.
Lol they stole that Idea from a old beetle Windshield water sprayer
I would still like to test it. Indeflate vs Mike
I don’t believe it is quicker than any other method. It is definitely more convenient.
Test criteria:
1) Make sure all 4 tyres are at 2.0bar
2) deflate to 1.0bar
3) reinflate to 2.0bar using one compressor
Best man wins against the clock.....
Again I don’t think speed is the issue because so often you stand around waiting for others to decide what pressures to go to or trying to find their air hose or welding up something that wasn’t fixed before they left or checking their social media. For me it is just a convenient piece of kit to use. Just like it is a nice to have if your compressor is vehicle mounted ready for action.
If inflating/deflating is not a huge hassle you would be more inclined to change pressures and in so doing travel even short distances with the correct tyre pressures which is safer and could save you a tyre in the long run.
