Heat shrink tubing with adhesive..where to get in SA
- Has thanked: 804 times
- Been thanked: 1347 times
Re: Heat shrink tubing with adhesive..where to get in SA
Try Wurth...
- Has thanked: 86 times
- Been thanked: 70 times
I've not heard of heat shrink with adhesive inside. I use tons of heat shrink. I buy from Electrical wholesalers, electronics shops, sometimes even builders (if I'm desperate), and as Manny mentioned, wurth also supplies, but they're very expensive
- grips
- Has thanked: 111 times
- Been thanked: 250 times
Anthony I do agree with you. The only heat shrink I know of with adhesive is the ones used on 11000 Volt and higher cable joints and Cable ends.
Or maybe I am about to learn something new.
- ThysleRoux
If applied right "normal" heat shrink will seal the joint properly. (I have also never heard of an adhesive version)
FLEX is UNDERRATED
FLEX is UNDERRATED
