Winches & Winching
How many times a year do you use your winch ?
Less than once
8
40%
One to 5 times per year.
7
35%
More than 5 times per year
5
25%
Total votes: 20
Anthony Forgey
Has thanked: 44 times
Been thanked: 31 times
Post by Anthony Forgey »
1. Do you have a winch? Yes. Warn 9000lbs, dynema rope.
2. If not, would you ever fit one?
3. If you do have a winch, how many times per year have you used it & to help whom (yourself or others)? used about 20 - 30 times a year to recover myself and others. Probably 50% myself and 50% others
Has thanked: 453 times
Been thanked: 890 times
But Ant, you are the exception to the rule! :D :) ;)
Has thanked: 22 times
Been thanked: 103 times
Well Manny, if you go out more with us, then will use our winches more.
Why?, Do you guys get stuck a lot....
Anthony Forgey
I do :| :o ;) :lol:
Jadranko
Has thanked: 28 times
Been thanked: 94 times
Post by Jadranko »
now,this is 2500lb winch.
hopefully there is enough photos from all angles to give full picture of situation.
whole of mass of pikup was resting on transfer case skid plate.
no wheel contact with ground.
first pull was made backwards to direct pikup away from a ditch on front right side.
winch was then relocated at front bumper for final pull(for some reason it fail to make any photo or video,sorry for that )
same winch made pull of same pikup up the 20 degree incline over 4 meters in length....
....it could pull further but incline was over.. :D
Has thanked: 238 times
Been thanked: 206 times
joe wrote:
Tue Aug 22, 2023 8:54 am
Joe, can you give me more info on the winch you used here and how you mounted it.
Thanks.
Paul.
Has thanked: 194 times
Been thanked: 308 times
Paul#25 wrote:
Tue Aug 22, 2023 11:31 am
Thanks.
Paul.
That looks suspiciously like a MacAfric 2500 from Adendorffs.
https://www.adendorff.co.za/macafric-ew ... -gwinch201
PsyPhin
Has thanked: 64 times
Been thanked: 86 times
Post by PsyPhin »
I had to use my winch over the weekend. Didn't have a choice.
My 3 year old asked me what it was and when I told him he demanded to see if it was better than the winch Chase has from Paw Patrol. So I unwound it and let him play.
Jadranko
Post by Jadranko »
above is correct.macafric 2500 and wireless remote as extra .
winch comes with 4mm base plate and this is replaced with 20mm aluminum plate(6082) that is little oversized.
this oversize allows winch to be bolted or attached using soft shackle to a front hitch receiver ,
plate above tow ball(rear) any recovery point,rock sliders....
all of this allows winch to swivel and pull in a straight line no matter where anchor point is(left or right,up or down )in orientation to a car.
to a certain degree
PsyPhin
Post by PsyPhin »
Does this count? Didnt have close enough trees for the hammocks :mrgreen:
But, while messing around I noticed the hooks clevis safety pin was gone AWOL, so probably a good thing I spooled it out.
Rechardt
Has thanked: 93 times
Been thanked: 75 times
Post by Rechardt »
I love my Runva
1st time I used it to recover a Patrol at AT se gat.
Sent from my SM-A515F using Tapatalk
RechardT
Hilux 4l V6
Has thanked: 186 times
Been thanked: 246 times
#43
Winch? Not that much
Whinge? Quite a lot happening from the passenger sear
henris
#44
Post by henris »
Tons of respect for a Warn. I opened mine and serviced, after 12yrs of heavy service.
Fitted a cordless remote and that is a total winner.
Do I use mine often, yes very. Used it again, 2 days ago, to load in Moremi.
