LandRover Disco 1 V8i
is the temperature staying down?
Apocalypse wrote:is the temperature staying down?
Maybe because its raining this weeek...
Reenen wrote:
Oppies3800 wrote:Well, the connections did not make proper contact. Sprayed contact cleaner into it.
Rewired the fans to run of a switch inside the cabin and now they run from start up
Kom jy kamp met hom?
Ja. Hy gaan Breederivier toe
Enjoy
Well, it did not make it...
Top gasket
Lekker fix this [emoji848]Image
Would it not be better to fix the underlying overheating problem first?
Oppies3800 wrote:
Mon Nov 05, 2018 12:13 pm
Not bad ! Are you doing the job yoursef ??
Estee
Post by Estee »
Oppies3800 wrote:
Wed Oct 31, 2018 3:59 pm
That will work
AndreasR wrote:Would it not be better to fix the underlying overheating problem first?
Its overheating as the headgasket isn't sealing so its not circulating water properly.
Headgaslet went due to the faulty thermostat
Yea we are.
Rebuild a D2 V8 in a week.
This can't be too difficult
Started last nightImageImage
Heads went in for some maintenance Image
Finished...
Back in my driveway!Image
Sterkte
